20 Most Recent
Dell Inspiron 1720 17" Widescreen Notebook, 2.0GHz INTEL CORE 2 DUO, WiFi, 2GB RAM, 500GB, CDRW/DVDR... (883585945740) Questions & Answers
Can I install an hdmi hook up to my computer
Hi Art,
Dell Inspiron 1720 doesn't have an HDMI port. However, you may try using any USB to HDMI connectors available in the market which might help.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Inspiron 1720
Smarktey Password Recovery Bundle is a must-have toolkit to recover/remove/reset passwords for Windows, Excel, Word, Access, PowerPoint, Outlook, Outlook Express, SQL Server, RAR/WinRAR, ZIP/WinZIP, PDF, MSN, AOL, Google Talk, Paltalk, Trillian, Miranda, Opera, Firefox and IE Browser, etc. Over 80+ types of passwords can be recovered instantly. Until now, this
password recovery tool is the fastest and easiest one to use and the least expensive on the market.
http://www.recoverlostpassword.com/products/passwordrecovery.html
Hi
I have Dell inspiron
That's an interesting problem. It sounds like it's applying new display settings, but I'm not sure why it would do so over and over again. I would suggest trying to start Windows in "Safe Mode". To do that, as the computer is booting, hold down the F8 key to get the "Advanced Boot Options" menu. Maybe this will get you to a normal login screen. If so, you should try to change your display settings to the simplest possible and then reboot. I hope this helps.
My Dell Inspiron 1720 works with the battery, but
Will the Notebook work with the ac plugged in and the battery out. Most of the time it will be a faulty charger or even the port the charger plugs into. The port is soldered to the main board and would be something that a repair shop would need to replace. If you search the www you can find Dell compatible power supplies for Dell at less cost than direct from Dell
Battery light flashes
Flashing Blue/Green indicates charging, Flashing amber means battery overheating
You get a better indication of battery health from Windows and BIOS
My Letter aon my Dell Lap top is not working,
1.u can remove every keys in a laptop keyboard.see any website first to remove the key buttons.
2.then remove the keys which are not funcitioned properly,then clear any dust
3.Replace the key bottons
Thank U sir ... All The Best...
I have a problem with the wirless internet on my
your settings in the router at your new place may not match the settings in the old place. try typing 192.168.0.1 or 192.168.1.1 in your address bar and logging on to your router (this will require you to be manually plugged in with a cat 5 cable) default passwords are usually admin/admin or admin/password. check your settings to see if something is preventing you from getting on.
Infected by trojan-spy.html.citifraud. i need a
Hello sir/ma'am. Hi, there are several malware softwares available for downloads, visit
www.download.com for your anti-virus need or download combofix, if ever still the malware insist, back up your important documents and format your hard drive. Install a clean OS, use 2 partitions, one for your OS (your c:) and the other for data (your d:). so next time this things happens, just move all important documents to the data drive (d:).
I forgot my sign on and i dont have those disks to
Turn on the computer, as soon as you press the power button, keep tapping F8 until a black screen with options comes up.
Choose the Safe Mode option. Once in Safe Mode, logon with the Administrator account. Once logged on, go to Control Panel to change the password for YOUR user account. Restart back into normal mode after that.
