20 Most Recent ASUS Eee 900 Notebook Questions & Answers
Access fan and heat sink
http://www.youtube.com/watch?v=nIthAeN49hIAnd food for thought,http://www.youtube.com/watch?v=yPIlOuxAWREWEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.Average cost is around $3 to $6.A CPU (Processor) is the hardware component, that is the MOST susceptible to Static shock.For additional questions please post in a Comment, or click on Reply at end of solution.Regards,joecoolvette
5/13/2013 7:39:41 PM • ASUS Eee 900... • Answered on May 13, 2013
Computer shuts down after 10-15 min
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
5/13/2013 11:04:30 AM • ASUS Eee 900... • Answered on May 13, 2013
L becomes a 3
Turn off your number lock. You have the keys in calculator mode.
12/14/2012 12:35:05 AM • ASUS Eee 900... • Answered on Dec 14, 2012
I want to change my asus 333 pc from chinese language to english
Which Operating System?
The display language is the language that Windows uses in wizards, dialog boxes, menus, Help and Support topics, and other items in the user interface. Some display languages are installed by default, and others require you to install additional language files. When you change the display language, it is changed for your user account and is not changed on the Welcome screen. If you want to set the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
3/26/2012 3:37:49 PM • ASUS Eee 900... • Answered on Mar 26, 2012
Want to reformat EeePC900 back to factory
When your system is start then hold f8 key and bios setting will be appear hear will you change your restore factory setting. Or when your bios setting will not open then hold delete button then it appear.
11/7/2010 11:12:23 AM • ASUS Eee 900... • Answered on Nov 07, 2010
I am trying to type
Tony,
You will have to install Russian fonts to your computer. To do that type russian fonts ig google search window and press enter. You will be shown both, free and paid fonts for russian. Download and install to your computer and you are on.
9/12/2010 11:28:19 AM • ASUS Eee 900... • Answered on Sep 12, 2010
2answers
I wish to change the language from french to on my ASUSEss PC900
You need to to windows update and choose custom updates. French will be one of the selections it may ask you for your Windows CD.
7/3/2010 12:24:32 PM • ASUS Eee 900... • Answered on Jul 03, 2010
Windows root system
If you can repair the windows then boot with original OS cd and follow the instructions that how to repair installed windows.
If this repair process unable to fix this issue then you need to install a fresh copy of Windows. But remember if you want to install fresh copy, you will be unable to access your previous data on your drive C:\
Best of luck.
Regards;
Hasan
12/30/2009 11:17:03 PM • ASUS Eee 900... • Answered on Dec 30, 2009
I have internet but it wont connect keeps going on
call the isp or the manufacturere of the computer
10/19/2009 8:22:30 AM • ASUS Eee 900... • Answered on Oct 19, 2009
Asus eee 900 wont kick in
is the scrren compartible?is the board working properly?why is the fan not working ?the connections were bad try doing them over again. good luck.
7/4/2009 7:31:05 PM • ASUS Eee 900... • Answered on Jul 04, 2009
Very Slow
need to download adaware software and remove all spyware from system. Also run disk cleanup under the accessories and system tools tab
6/6/2009 2:04:09 AM • ASUS Eee 900... • Answered on Jun 06, 2009
2answers
I put 2gb of DD2 ram in 800 mhz it wont show a screen? To fast of
Eee PC models use 533/667 MHz DDR2 RAM via a standard SO-DIMM module.
The hardware supports up to 4GB (2GB for the 1000 series, and some of the 900 series).
2/25/2009 3:29:04 PM • ASUS Eee 900... • Answered on Feb 25, 2009
2answers
How to load new ssd for eee pc
By SSD I assume you are refering to a Solid State Drive to replace your existing hard drive. If this is the case you need to install the drive and then boot off the CD that came with your computer and reinstall the operating system. Note that all you old info will still be on the original hard drive but you can still access it by purchasing a 2.5 inch USB hard drive enclosure. When you plug it into a USB port it will be detected as a second hard drive.
1/3/2009 5:31:55 PM • ASUS Eee 900... • Answered on Jan 03, 2009
My asus eee pc 900 wont work
open the cpu cover then refix RAM then checl if problem still remains
then u have to reinstall reapir win xp
1/1/2009 7:58:24 AM • ASUS Eee 900... • Answered on Jan 01, 2009
Need to change language from
Well if you are using the operating System WinXP.
Click on start then to control panel then to Regional and language options then click on the language tab at top then click on details there is where you change the language.
Hit Apply to save the changes you do
Happy Holidays
12/25/2008 12:12:58 AM • ASUS Eee 900... • Answered on Dec 25, 2008
Change language asus eee 900
Try this, this is the solution if you are running Windows XP:
To change the language used for menus and dialog boxes
Open Regional and Language Options in Control Panel.
On the Languages tab, under Language used in menus and dialogs, click the language you want.
Notes
To open Regional and Language Options, click Start, click Control Panel, and then double-click Regional and Language Options.
This option is only available in the Windows Multilingual User Interface Pack. If you are interested in this product, please contact the Microsoft office nearest you for more information.
12/24/2008 10:33:39 PM • ASUS Eee 900... • Answered on Dec 24, 2008
2answers
Wd 11 error code:0xc0000034
The last line of your error message contains the solution: "You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a disk or USB device), contact your system administrator or PC manufacturer." Translation: Start up from the disk that came with your laptop and follow repair tool instructions (or contact the manufacturer to obtain a copy - which you may possibly need to purchase. If you are not under warranty this will possibly be at a reduced cost.) Look for a label on the bottom of your pc for a phone number for service if your equipment is not useable. Good luck!
7/21/2022 8:42:08 AM • ASUS Eee... • Answered on Jul 21, 2022
Keys all mixed up keyboard
check using the onscreen keyboard or you can also check with an external keyboard to see if the same issue occurs with those. if it does the issue could be a software related. you can go to device manager, under keyboards uninstall the Keyboard Device and restart the computer.
10/7/2019 8:44:22 AM • ASUS Eee... • Answered on Oct 07, 2019
ASUS Eee 900 Notebook Logo
26 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
computer shuts down after 10 15 min
  • Computers & Internet
