20 Most Recent HP Pavilion dv7-1130us laptop Questions & Answers
My HP Pavilion dv7 will randomly restart itself, but Only when the battery is being charged. It never happens unless the charger is plugged in. I am not moving the computer when it dies, sometimes it
not shut off, right, it reboots, but never actually shuts off. so the battery is bad. if the PC runs ok, no big battery the battery is bad. the all love to short why expect less from any relic battery.? and the RTC coin cell is too relic>? yah most geek shops cant fix thing , no ports to fix them.. after all no 2 laptops are the same, (sux in my book) buy a battery , if the AC pack runs the PC all day. ok?
12/10/2017 8:58:27 PM • HP Pavilion... • Answered on Dec 10, 2017
2answers
My HP Pavilion dv7 is not powering up, it just
I would suggest disassembling it, checking for breaks in any cables, loose cables etc, then assembling very slowly, checking everything as you go along, good luck.
10/26/2017 1:39:53 PM • HP Pavilion... • Answered on Oct 26, 2017
I have an HP dv7-1426nr model. My HDMI was working
a laptop DV7 connected to what, TV, no TV stated, must we beg? on my huge 55inch LG, i click on the LG input screen , the HDMI that is connected to the PC> HDM1,2,3,4, etc. then it works. using auto connects in HDMI are not reliable, its a bad design. you must force it. even on both ends. I have many HDMI connected to my TV , BR-D , even have a video server on mine, and more. so I must force them all , due to all are there running, and I must force mine every time. HDMI can be a pain this way. does you PC run normally, does your PC connect to other TV ok, does your TV connect to other HDMI devices ok>
10/21/2017 5:53:19 PM • HP Pavilion... • Answered on Oct 21, 2017
2answers
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad. in most cases. supper common failure.. 2008 PC. see page 31 , part 5 here. bingo, change that out. there are 2 types used, only your full PC part number on the service tag show this, post that and we go to the HP parts surfer and look it up. http://h10032.www1.hp.com/ctg/Manual/c01918142
9/28/2017 7:57:07 PM • HP Pavilion... • Answered on Sep 28, 2017
HP Pavilion DV7 bio password needed
If you could go online and just bypass the password what use would it be. Now you must do a full recovery to factory settings, this will erase all the data you have inputted and leave only the programs that were on the system out of the box new.
9/23/2016 11:14:21 PM • HP Pavilion... • Answered on Sep 23, 2016
How to replace dv7 1130us cpu
When replacing a CPU. Make sure the new CPU is compatible with the device you are trying to upgrade. You are going to enter into the BIOS. Download this PDF manual to be aware on how to get into these settings. http://h10032.www1.hp.com/ctg/Manual/c02642701.pdf The physical part with replacing the CPU hardware. CAUTION!! DO NOT FORGET TO HAVE THERMAL COMPOUND BEFORE PLACING THE HEAT SINK ON THE CPU. IF YOU DO NOT APPLY THERMAL COMPOUND, THE CPU WILL OVER HEAT AND MAY CAUSE YOUR UPGRADED CPU TO BURN OUT. LINK TO LEARN HOW TO APPLY THERMAL COMPOUND; http://www.computerhope.com/jargon/t/thercomp.htm Good Luck.
9/12/2016 1:34:37 AM • HP Pavilion... • Answered on Sep 12, 2016
Cant turn insert off of my keyboard on my hp pavilion
Try pressing the insert key again. It should disable it.
9/11/2016 7:24:25 AM • HP Pavilion... • Answered on Sep 11, 2016
Batterie 601 remplacement
go either on the hp website or ebay eBayeBay from au-battery-store.com http://battery-store.com/
11/22/2015 9:40:21 AM • HP Pavilion... • Answered on Nov 22, 2015
No drag and drop as well as other windows errors due to pleomax mouse - how do I fix it?
Get a new mouse, can't find any support for that mouse. Mice are very cheap.
4/5/2015 6:28:57 PM • HP Pavilion... • Answered on Apr 05, 2015
How to replace dv7 main board
omg good luck.
3/11/2015 7:43:08 AM • HP Pavilion... • Answered on Mar 11, 2015
Loose hinges how do I tighten them
Watch the video it shows which screw hold the hinges to computer itself and to the screens back cover. HP DV7 LCD Screen Replacement
3/11/2015 7:09:06 AM • HP Pavilion... • Answered on Mar 11, 2015
Why number keypad doesn't work (even num lock is pressed)?
did you try holding down the (fn) key and pressing "num lock?"
2/19/2015 3:13:45 AM • HP Pavilion... • Answered on Feb 19, 2015
2answers
My hp laptop is not powering up
if you are not using the power supply, please do so. some of the laptops will not power up if the battery is bad, but depending on the year, a replacement battery is not very expensive. if you know how to use a volt meter, you can check the output of you power supply to see if it is bad, if it is good, i would take the laptop and power supply to a service location to be tested. If the laptop is very old, consider replacing it, if not repair, depending on the cost.
12/25/2014 10:42:22 PM • HP Pavilion... • Answered on Dec 25, 2014
My hp does no detect power plug but works on batery
Hi, First you need to establish if it is the power supply or the computer that is at fault. First, verify that the power supply is functional with a voltmeter or another computer. Second, assuming that it is OK, (always remove the battery when troubleshooting power feed problems) connect the power supply to the computer and wiggle the plug lightly all the while pressing on the power button to see it you can establish contact and start the computer. Usually the jack in the computer becomes defective when one of its wires cuts near the jack. This wire can be resoldered or the complete jack assembly replaced.
12/25/2014 9:57:30 PM • HP Pavilion... • Answered on Dec 25, 2014
On a DV7-1130US the charging light blinks 8 times and will not let the laptop start up.
These blinks [flashes] are fault indication (Error Codes). If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
10/29/2014 12:42:11 PM • HP Pavilion... • Answered on Oct 29, 2014
Why do i keep getting an Error code 32 on HP DV7?
error 32 usually means that you are having a problem with a driver Code 32 is an error generated by the device manager. The device manager is a native Windows tool for performing administrative action on hardware devices and their respective drivers. When a driver experiences a problem, it reports it to the device manager. These errors are not uncommon, but may be causing detrimental damage to your computer and causing the loss of functionality of one or more of your hardware devices. Hardware devices (video card, sound card, printer) utilize drivers as a resource for interfacing with the operating system. These basic functions are essential for the normal operation of your computer. The Code 32 error message indicates that the device driver or required services associated with the driver are disabled. Drivers are often supplemented with services that provide functionality and process support for general device operations. Typically, when this technology is implemented, the services provide essential functionality for the device and may cause the device to malfunction or be unresponsive, if not active. Common causes of Code 32...
  • A required service associated with the device driver is disabled.
  • The device is not up-to-date.
  • The driver is corrupted.
  • A previous attempt to update the driver failed or was interrupted.
  • The device is not configured as the default.
  • A different device is providing default functionality
if you have a few hours to spend manually pin pointing the Driver that needs to be updated or reinstalled go to the link below. Manually Fixing Code Errors If you are lazy enough to pay 29$ to do it the easy way use this link. http://www.windowsanswers.net/go.php?r=driverupdate you will be able to get a driver update software as a set up file it will scan for updates for your drivers return results of how many it found and when you hit install will ask you to register software for $29 dollars. But before you any of that I would suggest that you go to the HP link below and hit the scan button and let HP check for driver updates for your computer. HP Pavilion dv7 1130us Entertainment Notebook PC Drivers
7/8/2014 4:22:46 PM • HP Pavilion... • Answered on Jul 08, 2014
Hp probook 470 g1 starts fine but nothing on my screen, works on my tv but not laptop. only a week old have I done something
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
6/4/2014 9:21:28 AM • HP Pavilion... • Answered on Jun 04, 2014
HP Pavilion dv7 screen is off center making task bar at bottom off screen.
set you resoultion to a different setting
5/16/2014 2:51:14 AM • HP Pavilion... • Answered on May 16, 2014
When I connect my HP Pavilion dv7 to my Sony
how do you connect your pc with tv, with d-sub cable or with hdmi cable. If you use d-sub try to lower the screen resolution start with 1024x768.
4/13/2014 2:53:07 PM • HP Pavilion... • Answered on Apr 13, 2014
HP Pavilion dv7-1130us laptop Logo
250 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
  • Computers & Internet
