Try Data Recovery Software!
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
enter wrong password for 15 to 20 times...ur mobile ll be locked and PUK number ll be asked...now call ur customer care from another mobile and get the PUK nummber...it s to be noted that PUK number can be got thro automatic voice recording in ur customer care number.....now enter the PUK number in ur mobile....... Ur mobile ll be unlocked.....
hope this helps......
thank u!!!!!
You must have received a USB cord and a driver installer CD with the package when you bought the cell phone. Install the software from this CD, connect your phone to your PC with the help of this USB cord. Thereafter, you should be able to transfer your pictures, music, etc., to your computer and vice versa.
Sometimes a phone won't turn on until you have enough charge in the battery to enable this. What I mean is if the battery is so flat, it might take ten or so minutes to start to so a charging state.
Sounds like a defective Sound chip in your device.
I suggest taking the following actions:
1. Remove Battery, Attempt to Restart phone. repeat at least twice.
2. Perform a hard/factory reset.
a. for most phones the go into your phones setting and look for a reset option.
b. Follow the prompt to reset your phone to factory settings.
c. Make sure to back up all you data
3. Contact a service representative of your carrier or take the device
into your carriers store, most of the time they will recommend doing a hard
reset as shown above, they will NOT replace a device without doing a
factory reset on the phone.
Good Luck!
Your phone probably came with a usb cord, plug it into your computer and into your phone. Then your computer should recoginze a new device being plugged in, if your phone software needs to download, let it do so then you will beable to go through the memory on your phone and save what you want :)
Keep entering the code till your phone asks for the PUK code.Then enter the PUK code which is available on the card which had your sim.After this reset your pin and enter a new one.
Try the last 4 digits of your phone # and if that doesn't work call up the place that you purchased your phone from and they should be able to help you out.
Hold down the VOLUME DOWN button, MENU button (the one on the keyboard), and CAMERA button for about 5-10 seconds, and a message will come up asking if you want to factory reset the phone,then select yes and then your phone would be reset,NOTE:This may clear off your entire phone memory items,make a back up of it...Hope i have helped you..
Hi this is a very common problem with all flip and slide phones and even laptops and notebooks, the problem is to do with the data ribbon that connects the screen to the circuit board in the bottom of the phone. now inside this ribbon are several single strand copper wires and over time open and closing the phone causes these to break and you then lose the connection with the screen.
as this is such a common fault it makes the part itself cheap to buy and cheap to get fitted. it isnt something you can do your self as you need specialist tools to take the phone apart and to fit the data ribbon.
if you want it repaired the cheapest place would be one of those small independent phone shops as the bigger one will have to send it off and you will be charged extra for this, the smaller phone shop should be able to fix it whilst you wait or the next day at the latest.
its up to you if you think the phone is worth getting fixed then it wont cost much to get done.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
