20 Most Recent
LG Rumor LX260 Cellular Phone Questions & Answers
How do i unlock my lg rumor from sprint to do anything?
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
Broken usb charger port on a nokia n86. has anyone
Go to nokia center. I broke my USB port too. I told the staff at nokia care and they agreed to fix it since my phone is still in warranty. I told them i accidentaly broki it and they said they will log it as factory defect. Nice :) I got it back now and they cahnged the entire board.
Phone wont turn on
Plug charger in over night, try and power on.If it still doesn't the phone is probably broken and you may need to purchase a new one.
Screen lock after a short
1. Touch > Main Menu > (slide the screen up) >
Settings > Display > Backlight.
2. Select Backlight Dim or Backlight Off.
3. Touch a time setting.
Can't disable lock feature on LG rumor touch
hi, it is very possible to unlock it permanently or increase the time..all you need to do is to go to setting on your phone...check your phone setting, then try to locate your automatic key guard....you could increase the time or you select off..
My phone is only showing , black and white
There are two things that can cause this and you will likely not be able to cure this.
The LCD display is scanned by integrated circuits and if the scanning hangs, the circuit fails or a delicate contact strip isn't in the right place on the LCD assembly, you can end up seeing a scan that isn't happening.
You can try pressing gently randomly around the surface of the LCD. If you see a flicker of characters or images, then the contact strip is at fault.
These are the possibilities but I'm afraid it takes very good manual dexterity and some special tools to correct this at a minimum and if circuit failure is at fault, a new board is needed.
Voice command on Gu290f mobile phone
I have a LG GU290f mobile phone but my display screen is white and I can't see anything but the phone vibrates and rings when I get my messages and calls I can speak and hear the call properly only my display is white.
I just bought an LG rumor from ebay.. the phone is
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
The keyboard on my lg rumor lx260 isnt working
most cases having to do with the keyboard, screen, volume buttons or other parts of the phone is mostly related to the flex cable. the flex cable is a thin bunch of tiny wires that are joined together and form a flat extended cable. it is most likely that your phone is suffering from a problem of either a weak or faulty flex cable which needs to be changed.
my advice is that you send it to a repairer because it is a very delicate process which requires some level of expertise. depending on the type of phone and how common it is, the flex shouln't be too expensive for a phone like yours.
hope this was helpful?
please rate
