20 Most Recent
LG KG375 Cellular Phone Questions & Answers
I need a manual for a LG KG 375
You can download and print the instruction manual in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
11/29/2010 10:37:52 AM •
LG KG375...
Answered
on Nov 29, 2010
Display problem
Lahore (042)
Appliances & TV Service Center
LG-Plaza, 11-A, Lawrence Road, Lahore
Tel: +042-7210273, 7242611-089
Send an E-mail.
Mr. Saadi (TV/PDP/LCD TV)
[email protected]Mr. Aqeel (Appliances)
[email protected] GSM Service Center
Siddique Center LAHORE
SAJJAD/SARAJ
Tel: 042-578-9918-19
LAHORE MALL
SHAHZAD
Tel: 042-732-0894
1/19/2009 1:30:31 PM •
LG KG375...
Answered
on Jan 19, 2009
Need puk sim unlock code
on your service provider site enter with your no. and you can get puk code or visit costumer care ..
Internal memory full
You have not mentioned any model number in specific for your phone, however you can use a memory card on the phone and set the memory card your storage device
10/24/2013 11:44:47 AM •
LG KG Cell...
Answered
on Oct 24, 2013
UNLOCK PUK COD
You can get the PUK code from service provider................
Unlock sim for LG800g
i think your phone blocked or locked from network. you need to unlock your phone through imei unlock code. after unlock your LG phone. you can use any GSM sim Card in your LG phone.Hope this will help you.
Enter puk
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
