20 Most Recent
Microsoft Wireless Desktop 3000 Keyboard Questions & Answers
Magic key
Install the driver of the keyboard.
find the library or executable which loads the user environment commands and put it into Win.ini or sinply dropit int the "Strat- AutoRun" menu section.
On Windows 7 and earlier versions of Windows, the Start menu contained a "Startup" folder to make this easy. On these versions of Windows, you can simply open your Start menu, locate a shortcut to an application you want to start automatically, right-click it, and select Copy. Next, locate the Startup folder under All Apps in the Start menu, right-click it, and select Paste to paste a copy of that shortcut.
10/5/2018 6:17:25 AM •
Microsoft...
Answered
on Oct 05, 2018
USB light for microsoft 3000
Go to Microsoft/help/support.com and you should find a solution. Sounds like you don't have the right hardware or a bad software pack. Also make sure the computer recognizes it. Try another keyboard if you have access to one. You'll probably have to go to another computer to get instructions and print then out and maybe you can do it with a mouse if it works and another keyboard doesn't work. If you can get another keyboard to work and download the drivers for the 3000 make sure the 3000 is plugged into the computer when you download the driver for the 3000.. They do have downloads for the 3000 I just went and looked and the last keyboard I had was a 3000 and I downloaded files from Microsoft.
Hope this cures your Microsoft headache;
dhgill1949
6/4/2011 11:19:57 AM •
Microsoft...
Answered
on Jun 04, 2011
I have been having an issue where my mouse becomes
Do you experience lag while playing the game? If the game lags, mouse movement will probably lag as well. Do you have another mouse/trackpad/input device you can try? If your other input devices work, it could be a problem with your mouse.
Check to see that you have the latest drivers for your mouse. It could be that obsolete drivers are causing the problem.
5/12/2011 6:07:58 PM •
Microsoft...
Answered
on May 12, 2011
How to slow the scrol
Assuming you are on Windows, go into your control Panel and go to your Mouse Settings. You show be able to slow it down from there. Scroll Speed will be where you want to adjust.
Start>
Control Panel>
Mouse>
Pointer Options Tab>
Select a Pointer Speed>
NOW ADJUST YOUR SPEED AND THEN CLICK OK
NOW Exit this small window if it doesn't do it automatically and VOILA you are done!
3/10/2011 5:30:29 PM •
Microsoft...
Answered
on Mar 10, 2011
Keyboard just stopped working. mouse fine. pressed
Check the batteries in the keyboard. If the batteries are good. Pull the connection for the Keyboard and plug back in. Tyr to resync Still nothing restart computer and resync the keyboard again if need be.
Good Luck.
Zeppelinx12
3/9/2011 1:23:57 AM •
Microsoft...
Answered
on Mar 09, 2011
NO MAJOR PROBLEM...JUST WANT TO
Hi there.
Underlining or bolding is the same with any mouse and keyboard that you use. If you want to bold a word or a letter, just hold down left click and hover it over on the word to highlight it, then press CTRL B (to bold it) or CTRL U (to underline it).
Alternatively, if you are using Microsoft Word or Excel, you can see these options on the toolbar.
Please let me know if you need further assistance.
Thank you!
2/6/2011 6:05:11 AM •
Microsoft...
Answered
on Feb 06, 2011
The
they may be jammed
7/15/2010 3:20:13 PM •
Microsoft...
Answered
on Jul 15, 2010
Mouse works but keyboard does not.
Ironically, when I replaced my dead HP Pavilion, on which I had the same wireless keyboard and mouse, things worked in the reverse but opposite method. The mouse doesn't work, but the keyboard does.
I suspect it is directly related to the config buttons on the bottom of each part. The buttons were supposed to sync such that the keyboard and mouse worked together perfectly and did, until I had to replace the PC.
My only suggestion is to continue to press those little buttons repeatedly, until they finally do sync all the way around. And most important, ensure that your mouse and keyboard have fresh batteries at all times, as that would make the whole process fail in the most embarrassing way.
Good luck,
-a.
7/14/2010 12:42:48 AM •
Microsoft...
Answered
on Jul 14, 2010
