20 Most Recent
Nikon F80 35mm Film Camera Questions & Answers
Latch for the Film door broke
This is so tedious a job that I would not try it myself unless I was adept in doing this right.Unless the camera costs a lot to start with, I would just get another SLR. I believe the cost in repairing it depending on model and the size, will be about $200. I say this because from experience, I had a $250 camera 20 years ago and the latch broke on mine and he said it would not be worth it to fix it. Unfortunately, it was way out of warranty.
Sigma lens APO170-500mm to fit on SLR camera body
Sigma makes lenses with a variety of mounts to fit a variety of cameras. A lens with a Canon mount won't fit onto a Nikon camera, for example. Assuming the lens has the proper mount for your camera, it should fit fine.
MY CAMERAS SAYING FEE, its
This is found in the F80 manual page 99. it means the CPU Nikkor lens (other than G-Type) is not set to its minimum aperture. Solution: set the lens to the largest f/stop such as f/22. This FEE error is the same for almost all Nikon cameras, be they film or digital.
Can't load the film in the F80 leader won't take
Open the camera-back. Look to the right where the take spool is there is a red mark. The leader should go to the red mark not any more. Now look at the inside of the camera-door, you should see close to the hinge a springy thingy-bob. If that is missing then when you close the door there is nothing to push on the film to seat it. On that spring is a chrome pin as well. Hope this helps you.
I have a 35mm nikon camera. I've changed the
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
My Nikon F80 won't turn on, I've tried changing
Hi darciegracem, Does this happen with the MB-16 battery pack using AA batteries? If so clean the contacts on the battery pack and inside the camera. Make sure it is screwed snug to the camera. If it happen when using the two 123 batteries as well, it may need a trip to Nikon. These cameras go used for about $100 or less thus, you may not want it repaired but, rather purchase a used one from a reputable dealer. The F80/N80 is a very nice camera.
I have a half way
You can force your camera to rewind, but you will
have a partially shot roll of film. If
you continue to shoot your counter will be off but when the film cannot advance
any more the camera will rewind.
Red-Eye Reduction Lamp
I own an F70 with similar lenses. I am not fully familiar with the F80, and therefore can't be sure what I am saying will halp, but I believe it is the next model of similar specs as mine. However, from your description, I think what you are saying is that the little red light that flashes, before the photo is taken and when you have the flash mechanism up, is no longer working, and that your camera is haveing difficulty getting a fix on the focus in automatic focus mode?
This red light is not the 'red eye reduction' flash, but rather a red light (so it doesn't make your subjects blink / squint too early) that helps the camera focus: Auto focus mechanisms need light too. If your light has stopped working, then that would explain why the camera can't focus. This should however only occur in low light conditions.
Fixes:
-Obviously, if it's still under warranty - take it back.
-Get it repaired
- OR if that's going to cost too much or you were thinking of doing so anyway, a dedicated flash unit MAY solve the problem. Most flash units have there own red light to aid autofocus. At any rate, you could take it in to a store and test a flash unit in-store to see whether it helps with the problem. If a dedicated flash unit didn't help (make sure you try it in a dark room - ask them to take it into a back room and try it) then it might suggest another problem such as: the camera is failing to send the signal to the red light to flash rather than the light not working. After all, the red light would be an LED, which have extremely long lifespans.
My Nikon FM has an issue where every-other time I advance the film the shutter mirror flips up and the shutter goes off. I can actually watch the mirror go up as I'm winding if I take the lens off
It sounds like your Nikon FM may be experiencing a mechanical issue with the shutter mechanism. Here are a few troubleshooting steps you can try:
- Inspect the Film Advance Mechanism: Check the film advance lever and mechanism to ensure they are functioning properly. Make sure there are no obstructions or debris interfering with the movement of the advance lever.
- Check the Shutter Release Button: Inspect the shutter release button to see if it's sticking or malfunctioning. Sometimes, a stuck or sticky shutter release button can cause the shutter to fire unintentionally.
- Examine the Mirror Mechanism: Carefully inspect the mirror mechanism to see if there are any visible signs of damage or misalignment. If the mirror is flipping up unexpectedly, there may be an issue with the mechanism that controls its movement.
- Clean and Lubricate: If the camera hasn't been serviced in a while, it's possible that dirt, dust, or dried lubricant may be causing the issue. Consider cleaning the internal components of the camera and applying a small amount of appropriate lubricant to the moving parts (be cautious and follow proper procedures when lubricating a camera).
- Seek Professional Repair: If the issue persists after attempting basic troubleshooting, it's advisable to have the camera inspected and repaired by a qualified camera technician. They can diagnose the problem more accurately and perform any necessary repairs or adjustments to restore the camera to proper working condition.
- Use a Different Lens: Sometimes, issues with the lens can affect the camera's operation. Try using a different lens to see if the problem persists. If the issue only occurs with a specific lens, there may be a problem with that particular lens.
It's essential to handle the camera with care during troubleshooting, especially when accessing internal components. If you're unsure about performing any repairs or adjustments yourself, it's best to seek professional assistance to avoid causing further damage to the camera.
3/16/2024 9:18:35 AM •
Nikon...
Answered
on Mar 16, 2024
My Nikon FE film advance lever is stuck. It does
Have you tried fresh batteries and setting the shutter speed dial to M90 or m250 whichever you have? If this does'nt work you can remove the camera bottom plate and gently pull a lever away from the advance cog. Some times things get out of sync in there. Sorry I can't be more specific but I did this many years ago. Good Luck.
4/8/2022 9:42:31 PM •
Nikon...
Answered
on Apr 08, 2022
How to replace nikon f3 shutter?
There are youtube videos on this type of repair to DSLR cameras and I dont recommend that you try it unless you have incredible talent for small details and a very clean environment.
6/22/2021 1:55:43 AM •
Nikon...
Answered
on Jun 22, 2021
My Nikon is coming up with “n1” where the numbers are displayed and the film won’t wind so I can’t remove it, what do I do?
On many cameras, a lens error means the lens is not set to is highest f/stop such as f/16 f/22 and the like. The lens must be put in that mode for the camera so that the camera electronics can auto set the f/stop as needed. First thing I would do is look at the f/stop on lens with manual f/stop settings; such as the Nikon 50mm f/1.8D making sure it is set to the highest f/ number (smallest opening). Remove the lens check the dial. Also, is the battery fully charged? If all that is okay then do the following couple of things; 1. Get yourself a film change bag, they look like a black plastic/rubberish T-shirt. Put the camera in there make sure the bottom is fully closed, put your arms through the sleeves, they have elastic keeping light out. Open the camera carefully remove the film canister then using your fingers rewind the film back into the canister. 2. Okay, you do not have access to a film change bag, easy get a thick blanket or two, go in to a closet, close the door, put a towel at the bottom, cover your camera as best as you can then do the same as if you were using a change bag. Important, make sure you are in a completely dark place without ANY LIGHT working its way through to you. Next, being as your are using film, big congratulations for that, purchase a change bag from Adorama, Amazon, B&HPhoto. Every film shooter should have one. Hope the above helps you.
11/2/2019 6:08:32 PM •
Nikon...
Answered
on Nov 02, 2019
