20 Most Recent TechnoMarine Ceramique Watch TCB02C Questions & Answers
2answers
Techno Marine MO4 Watch, Seconds hand doesn't reset to top cente
You do not need to return the watch. It has self adjusting features (operated by the owner). Pull out crown to the first click, then push and hold the pushbutton at 2 o'clock to adjust the hand. When done - push crown back in.
If it doesn't work, pull out crown to the second click and do as described above.
Rate me, please.
1/23/2014 1:07:35 AM • TechnoMarine... • Answered on Jan 23, 2014
How to reset a techomarine chronograph watch at
That worked well for the second hand, but did not reset the other two dials to the 12 O'clock position.
9/1/2013 7:31:39 PM • TechnoMarine... • Answered on Sep 01, 2013
I've lost the chronograph button above the winder.
mcdevito75, Best Bet with your Chrono watch is, check out a small watch repair shop in your area for that btton and replacement. A smaller watch repair shop may save you some money on costs.
6/22/2010 3:06:48 PM • TechnoMarine... • Answered on Jun 22, 2010
How do I remove links
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
1/14/2010 8:04:38 PM • TechnoMarine... • Answered on Jan 14, 2010
Stress fracture in case
Contact Technomarine http://www.technomarine.com/
6/4/2007 5:07:36 PM • TechnoMarine... • Answered on Jun 04, 2007
My husband just buy hes technomarine watch last septmeber and its not even 1yr yet now its battery is dead.shall he need to change it?
Yes, he should consult the support center, they will have a replacement for him, most especially if he still has warranty
5/7/2019 3:56:25 PM • TechnoMarine... • Answered on May 07, 2019
0answers
2answers
The watch is new but is not keeping time what should I do?
take it back for a warranty inspection it could be a simple flat battery
12/7/2015 1:42:00 PM • TechnoMarine... • Answered on Dec 07, 2015
TechnoMarine Ceramique Watch TCB02C Logo
8 questions posted
Top TechnoMarine Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
View Most Popular
  • TechnoMarine Watches
Most Popular Question
techno marine mo4 watch seconds hand
  • Watches
