20 Most Recent
Simmons 511070 4x32 22 MAG Riflescope - Glossy Black Questions & Answers
Scope insternal adjustments do not do anything.
One of the things about bore sighting is there is no shock to the scope. They are meant to have some shock that goes along with an adjustment. Try smaller adjustments and tap the tube of the scope with a screw driver handle after every adjustment. Not so hard you dent it but hard enough to get stuff moving. Hope this Helps FixYa up.
The elevation adjustment screw will
all scopes are marked for up or down with a " u or d" or a
"+ or -" for up and down
just dont forse the turret screws or you will bust the scope
My 22 mag 4x32 rifle
I don't know what you have done already, but, remember there are two areas to tighten. The scope rings to the scope mounts and the rings themselves around the scope.
you have hopefully forgootten one step.
If not, take it to your local Gun store and I'll bet they won't charge you much if anything for looking at it.
How do I change the
If you have the Blazer 3-9x32 tur the large ring just ahead of the rear eye piece. That should increase/decrease the mag.
