20 Most Recent
Whirlpool Duet Steam WFW9700VW 4.4 Cu. Ft. Front Load Steam Washer - White with Brushed Chrome Accents Questions & Answers
Code F05 -E02
According to the manufacturer, the error means the door could not lock. Check the door for obstructions when you close. To remove error, reboot the washer.
Whirlpool MFW9700SQ1 FH problem
there's a flow meter in the washer that could cause this part number WPW10110225 if you go here you can see it
https://www.repairclinic.com/PartDetail/Flowmeter/WPW10110225/1381535
also check the screens on the water valve,it's telling you the machine thinks it's not filling with water or it isn't filling,also this could be a bad pressure switch or the computer board but if you order parts from repair clinic you can return them and you have 365 days to do this,so first thing check the screens on the water valve,shut down the water and remove the fill hose from the washer and see if there's any junk in the screen,if so you can clean off the screen and see what happens or replace the water valve,if that looks ok the flow meter is probably gonna be it so this might be the part you want to change out,i can't remember how to test the flow meter,i carry one so if i see this error i pop it on and see what happens and out of the three times i've seen this it was the flow meter.hope this helps you can google how to check it the instructions on the tech sheet in your washer isn't that good but you can check it out.good luck with your washer
F1e1 error codes
Check the harness from the ccu .If all in tacked replaced the ccu.
Whirlpool duet WFW9600TA00 f35 error
F35 error code is indicating a problem with the water level pressure switch operation (key#20). There could be a blockage in the air dome or pressure switch hose (key#21). The air dome is located on the back of the tub on the left hand side
SUD means the washer has detected suds, or foam inside the basket. Suds will cause the washer to wash poorly, and it can lead to other issues. The first step is to confirm you are using H-E detergent. H-E detergent is formulated to get your clothes clean with less water, and without creating foam
F25 is a DRIVE MOTOR TACHOMETER ERROR. This error is one of the toughest one since it really does not narrow it down. I would do plenty of testing before replacing the expensive parts. If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
If everything checks out okay, you should think about replacing the MCU since it may not read your motor correctly.
