20 Most Recent
Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch Questions & Answers
The band links come apart
some bands have pressure pins holding them together and once the come apart wont hold again. take it to a jewelry store with a lazer welder and they should be able to drill out the old on and weld a piece of steel
Watch is running quickly for 5 seconds then stops
I think the problem is with the running wheel inside it.Please dont try to open it and repair it yourselves.Please take it to the nearest authorised service center and they will fix your problem or replace your watch free of cost if it covers the warranty.If you have any further doubts regarding your watch please visit(http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf).Hope you are satisfied..
Chrono hands
Please make sure that you have replaced your battery properly.I suggest you t reinstall it once again.
Let me know the result
How do I set the alarm on model wau111a tag watch
Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
Instruction manual
If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
