20 Most Recent
Viking - VT73 - 4 Button Random Code Mini Replacement Transmitter Remote Wi Questions & Answers
What does fob stand for
This term first started appearing in the latter part of the 19th century. By 1890 it had become a fixture. At the time, it referred to the ornament at the end of a pocket watch chain. Today, it refers to the four-button security control that you use to open or lock your car's doors or trunk. It may also have a have your remote starter system's activation button. The word fob is not an acronym but is, itself, the standalone term. You may find this type of information if you were to check at www.safecar.info, a site that features not only car safety information but also general auto information, as well.
My alarm system was set to open the car and disarm
hiit sounds like the remote control module is faulty or the wires have come offyou will have to remove the cover under the steering wheel and get a copy of the alarm wiring diagram and follow the central locking wires test them to make sure they are working and still connectedtime consuming but it has to be done to find the faultaires
I need the manual to
The Autopage XT-42LCD is used to operate two systems, the RF-420LCD and RS-622. Since you state that you need to activate a remote start that narrows it down to the RS-622. You can download the manual for this unit at the following link:
http://www.autopageusa.com/resources/RS622operationManual.pdf
Please help me
you will need to verify the antenna is plugged in correctly.
Lights dont flash when arming and disarming system
If the lights on your system are not flashing when arming and disarming, there could be a few reasons for this issue. Here are some potential causes and solutions:
- System Configuration:
- Check https://mmfinancials.pk/gold-prices-in-pakistan-experience-a-dip-in-line-with-global-trends/ the system configuration settings. Some security systems allow users to customize the behavior of lights during arming and disarming. Ensure that the settings are configured to activate the lights as desired.
- Power Supply:
- Verify that the system has a stable power supply. If the power is insufficient or there's an issue with the power source, it may affect the functionality of the lights. Check for any loose connections or power interruptions.
- Light Bulbs:
- Inspect the light bulbs associated with the arming and disarming indicators. If the bulbs are burnt out or faulty, they may need replacement. It's a simple fix, but it can have a significant impact on the visibility of the system's status.
- Sensor Issues:
- Some systems use sensors to detect arming and disarming actions. If these sensors are malfunctioning, they may not trigger the lights properly. Ensure that the sensors are clean, properly aligned, and functioning correctly.
- System Software Update:
- Check if there are any software updates available for your security system. Sometimes, manufacturers release updates to address bugs or improve functionality. Updating the system software may resolve the issue.
- Faulty Wiring:
- Examine the wiring connecting the lights to the security system. Loose or damaged wiring can disrupt the communication between the system and the lights. If you find any issues
My auto page alarm wont
I have 09 envoy 4x4 with auto page remote with electric start but it stopped unlocking my doors ? It worked and now nothing just locks and start work any fix to this issue ?
