Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps .
Hello
Just enter to this YouTube video. You can understand how the date can be adjusted. The date of all date-watches will turn around to next day at 12 midnight, ie, once in 24 hour. If you adjust the date before 12 Noon, it will turn around to next date at 12:01 noon. So adjust the date afternoon. See this video. www.youtube.com/watch?v=9PmrNwxi4ls
OK.
I have this same exact watch with the same problem. In November of this year, my watch just stopped with an inability to autowind itself. I'm a little mad because I have babied this watch, while only wearing it on special occasions (10x). What's the problem?
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
mcdevito75 here, Hello David, Tag Heur a very fine watch, First I would make sure it is the seconds hand that stopped and not the Chrono. hand, I would also go over any instructions that came with the watch, about the light scratches on the saphire crystal, the crystal is scratch resistant to a point, and can occur almost anyway, rubbing up against something harder than the crystal itself, (certain Stones and materials) even if your in a dusty place scratches can occur on any crystal. Check with your warrantee, you should be covered.
you can find an exper in the local shop where you buy the product and
they will give you specific service for your questions about your
product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to buy world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service when your login.
