20 Most Recent
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Questions & Answers
Delta swivel faucet won't swivel
Take handle off it has set screw that holds it on top of faucet after handle is off it has a locking collar they may have it to tight you can get a little wrench from hardware store that turns it. most are plastic so be careful if you try to move it you may try a little at a time to see if it free's up.
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
My Delta kitchen faucet is putting out small black particles with the hot water. What can I do to stop it?
Is the kitchen faucet the only problem? If not, then the water heater or other problem may exist in the water system.When you run the hot water, are the particles always coming out or do they go away after while?Black particles can be caused by carbon water filters. Do you have a filter? Those particles stop over time. Washers and "O" rings that are wearing out can cause black particles. I would check under the sink to see if you have any slow drips. You may see white, green or black colors along the fittings.I've also seen black particles from algae in the line. Maybe there's a leak somewhere in the system that dripping and cause the algae to form? Inspect your water lines and checking for leaks anywhere in the system may help. If you turn off all your faucets, washer, hose bibs and check the water meter, is it still moving? I'd check it every 15 minutes for an hour to see if there is a slow leak.Here's a diagram that shows all the parts:
PlumbingWarehouse com Delta Kitchen Faucet Parts For Model 470 472I'd also take out the aerator and see if it's clogged. You may have to change the washers and "O" rings.Parts and prices: (sample list)https://www.plumbingsupply.com/deltakitchenfaucets.html
Sticking of KWC DOMO model faucet.
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
Hose assembly
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
In our Delta signature 470
The only way to stop the leak where you push the button is to replace the wand/head. Delta has a lifetime warranty on there faucets. Call Delta at 1-800-345-DELTA (3358). Give them your model # and they will send you the head for free.
Faucet does not completely shut off when properly
This problem exists when the seats get wore a and there is no resistance to shut water off. Replace the seats and springs to correct this problem. Shut water off and remove handle with a allen wrench and retaining collar to expose the valve body to gain access. Once apart remove seats and springs and reassemble and problem should go away.
How can I remove wand
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
