20 Most Recent
Tefal 61621 Steam Cuisine 2-Cup Rice Cooker Questions & Answers
I have got a 3
have got a 3 tire steam cruise. Which I was given where can I get
instructions on how to use it please
How many ml of waters
Good afternoon, Lilywaters31:
If the vegetables, even carrots, are in small pieces, less water is needed, but carrots need more water than eggplant, and spinach needs very little water, even 50cc will suffice. One cup of rice will usually require 2 cups of water.
Chr
Lost my instructions.. How do I steam actual veggies?
- The water level as long do not overflow is ok. Ensure water do touches the centre of the element.It's important to ensure there is sufficent water in the base of the steamer by visually viewing the transparent water level gauage.You can top up water on the either side handle.Turn the timer on if you think that the food will cook at 20 min or so.A receipes will help and tell you to set the exact min for cooking.
Regards
Alan
Tefal Actifry 2 in 1 paddle is going backwards. Can anyone help fix this?
These devices use a synchronous motor, and they work on AC current cycles rather than voltage.
Normally you can make them reverse two ways.
Unplug and reconnect quickly until it runs the right way.
or
make it turn the right way by hand before turning it on by giving it a hand in the correct direction.
But backwards is not a problem, mine goes both ways.
How can I disassemble a Tefal Easy Fry EY1018 airfryer?
- Unplug the air fryer: Before starting any disassembly, ensure the air fryer is unplugged from the power source to prevent electrical accidents.
- Remove the basket and pan: Take out the cooking basket and pan from the air fryer and set them aside.
- Locate screws or clips: Examine the exterior of the air fryer for any visible screws or clips that hold the casing together. These are typically located on the underside or at the back of the unit.
- Remove screws or clips: Using the appropriate tools (such as a screwdriver or pry tool), carefully remove the screws or unclip the casing to access the internal components.
- Separate the casing: Gently pry apart the casing of the air fryer, being mindful not to force it and to avoid damaging any internal components.
- Disassemble internal components: Once the casing is removed, you may have access to the internal components of the air fryer, such as the heating element, fan, and control panel. Take note of the arrangement of parts and any connections.
- Proceed with caution: Handle internal components carefully and avoid causing damage or disconnecting any wires or cables unnecessarily.
- Reassemble: After completing the necessary maintenance or repairs, carefully reassemble the air fryer in the reverse order, ensuring all parts are properly aligned and securely fastened.
- Test the air fryer: Before using the air fryer again, plug it into a power source and test that it functions correctly.
If you're unsure about disassembling your Tefal Easy Fry EY1018 air fryer, it's advisable to consult the user manual or seek assistance from a qualified technician or customer support representative.
