Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller :
Enabled
Serial Port1 Address 3F8/IRQ4 :
Enabled
OnBoard IR Port :
Disabled
Parallel Port Address :
378
Parrllel Port Mode :
ECP
ECP Mode DMA Chnnel :
DMA3
Parallel Port IRQ :
IRQ7
OnBoard PCI IDE Controller :
Both
OnBoard SATA-IDE :
Enabled *(Make sure This is enabled)
Audio Device :
Enabled
Modem Device :
Auto
Ethernet Device :
Enabled
If you have got a
SATA III HDD, ie if it is a
Western Digital Sata III you need to
configure the jumpers to work with your older Sata interface port.(
Only Sata 1 & 2 ports on your Mainboard Socket 478). As for
Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the
BIOS!
A word of caution "
Updating the Bios is not for the Novice" Do it at your own risk.
Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
