20 Most Recent Brother MFCJ-220 MFC-J220 Inkjet Multifunction Printer - Color - Plain Paper Print - Desktop Questions & Answers
Brother MFC-L8690CDW Laser Printer. The scanner is making a clicking/rattling noise?
The only way to diagnose is to remove covers and trace the noise to the source. It will be a nylon cog that has jammed, moved or become worn. https://www.google.com/search?q=Brother+MFC-L8690CDW+Laser+Printer.+The+scanner+is+making+a+clicking%2Frattling+noise ..
1/20/2024 9:36:39 PM • Brother MFC... • Answered on Jan 20, 2024
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable. 1.cable problem 2cis problem
8/22/2022 8:35:50 PM • Brother MFC... • Answered on Aug 22, 2022
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
  • if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
  • Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
  • Press the Home button to return to the main menu.
  • Open the front cover of the printer (to access cartridges).
  • With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
  • The reset menu will now appear on the LCD display.
  • Scroll through the menu to select a color and yield to reset.
  • The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
7/31/2021 11:01:53 AM • Brother MFC... • Answered on Jul 31, 2021
Why is my Brother MFC-7630N displaying an "insufficient memory" when I try to scan?
Try scanning at a lower DPI setting. The machine is only rated to a certain DPI which is how much information it can handle per inch. Lower the DPI the more pixilated an image you get becomes when blown up but unless you are planning on printing 6/4 photos in A3 size then 600-1200 DPI is plenty.
7/30/2021 12:35:29 PM • Brother MFC... • Answered on Jul 30, 2021
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
7/30/2021 12:34:38 PM • Brother MFC... • Answered on Jul 30, 2021
My Brother MCF9130CW printer has the error Print Unable OA. Does anyone know what this error means? It is still quite new.
There is no such error code. Please check again
7/30/2021 12:03:23 PM • Brother MFC... • Answered on Jul 30, 2021
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
7/30/2021 12:02:55 PM • Brother MFC... • Answered on Jul 30, 2021
2answers
I have print unable 2A error so I am unable to print
Brother MFC 9840CDW 2A error
7/30/2021 11:41:25 AM • Brother MFC... • Answered on Jul 30, 2021
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place. 2. Lift up the front panel from the device. 3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit. Visit my computer
7/4/2021 6:41:21 AM • Brother MFC... • Answered on Jul 04, 2021
2answers
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
2/11/2021 7:18:15 PM • Brother MFC... • Answered on Feb 11, 2021
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
2/11/2021 7:17:08 PM • Brother MFC... • Answered on Feb 11, 2021
My Brother Printer MFC 9840CDW is giving an error,
Try universal uninstalling printer, thethen run found new hardware wizard.
2/11/2021 6:23:43 PM • Brother MFC... • Answered on Feb 11, 2021
Brother is in an error state
4 Solutions of Brother Printer In Error State Windows 10:- 1. Beginning of all, you want to make sure that all the wires and joints of the printer are fit and don't have a loophole. 2. Make sure your machines connect correctly, try with Another USB port and the network or cable you use for the attachment has no problem. 3. Further, Switch off the printer and check for paper jams then close all trays accurately. If it has a paper jam gently remove it. 4. Verify if the printer is low on ink, refill it if it is. If you are using a WiFi printer, turn on the WiFi of the printer and the modem router. The cause why you get this error state note on your Brother printer is either your printer is not connected perfectly, the printer jammed, low on ink, and any software changes. There can be other reasons as well, which can cause the problem of the Brother Printer In Error State Windows 10. Full Blog - Brother Printer In Error State Windows 10 printer-support-3-undefined-undefined-0_81.jpg
8/21/2020 8:15:19 AM • Brother MFC... • Answered on Aug 21, 2020
How to fix unable to print 50 error in Brother J315w printer
Clean matance box
4/14/2019 9:09:14 AM • Brother MFC... • Answered on Apr 14, 2019
No paper error on mfc 7340
3/29/2019 7:05:22 AM • Brother MFC... • Answered on Mar 29, 2019
Find flash ocx file
Download the file of flash9f.ocx https://unfitpc.com/flash9f-ocx fix the corrupt missing or invalid files in the system without facing the complication too much
9/27/2018 10:47:22 AM • Brother MFC... • Answered on Sep 27, 2018
Brother MFCJ-220 MFC-J220 Inkjet Multifunction Printer - Color - Plain Paper Print - Desktop Logo
2 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
language setting brother mfc 6890cdw
  • Office Equipment & Supplies
