20 Most Recent
Lexmark Pinnacle Pro 901 All-In-One Inkjet Printer Questions & Answers
How do I bring the printer out of the power save
Usually, pressing the power button, brings the printer out of power-save mode. Sometimes, the printer gets hung. If this happens, disconnect the power plug, wait 30 seconds and reconnect power.
Black ink tank is full-printer says empty!
Run a head cleaning mode this will usually fix the problem. If the machine hasn't been used for a while you might have to get in there with a q-tip a denatured alcohol and clean it.
Can not connet to print
make sure power is on, cable is plugged in between printer and computer, and that the driver is loaded on the computer.
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
