20 Most Recent
Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude Questions & Answers
My ecosense 180dvn sends out an error code of 13
I have the exact same problem with error code 13 on my Rheem/Ecosense 180dvn . The unit ran good for at least a year, and then I started getting the same error 13 every few minutes. I called the Rheem service department, and they told me to check the vent installation as well as the gas pressure. I reinstalled the vent with new seals. I only have about 6 ft of vent, so there should be very little resistance. I checked the gas pressure, and it shows 9 in H20 pressure, which is well in the range recommended. The service center scoffed at the suggestion that it could be their circuit board. I am totally at a losss and at the verge of ripping this very expensive installation out of my attic.
Where is the flame sensor?
it will be close to the fire ring and is a photo electric cell
it registers flame light and cuts off the fuel supply with in seconds if the flame doesn't appear
Btu rating on natural gas meter
Gas meters are usually rated in cubic feet per minute (CFM) not BTU. there are 1027 BTU per cubic foot so do the math. Try the link below Btu rating on natural gas meter
What does code 13 mean on a tankless eater heater
Error code 13 referrs to the gas pressure and or venting issue. Please ensure the gas pressures are correct and the vent is free of any obstructions. It also may be a failed ecu chip. Service tech may be required but first check for obstructions in intake/exhaust venting. Bird nest- bees and foreign material.
Flashing 1L on screen what is the problem and how
if you are saying you instaled it 8 months ago, if you are not licensed you have voided your warranty,,, if you had it installed you do have at a min of 1 year labor and can call your installer, when they started doing the tankless water heater there installers are supposed to go to classes for installing these units and the company's that manafacture them will provide you with assistance on any problem, in your book it will tell you what is wrong on the code page if you don't have the manule go to there website they have all the codes listed,,
Rheem Eco-180dvn. Error code 12
actually, does it give you a big rumble? if it does, then your problem is that the meter's btu's are not high enough and there's too litle gas getting to the heater so it's blowing itself out, basically. you'll need to call your gas provider and ask for them to bring in a higher btu meter. around 220,000 btu meter is best, so your furnace and gas stove(if you have one) dont take to much gas themselves, meaning dont get a 180,000 btu meter, because it would only be able to supply the heater.
I get a P1 error code
Water inlet temperature to the heater is the same as preset on the controller.
I had this happen to me becouse I have a solar tank with temp of
135 farenheit.
Once I bypassed the sollar tank..no problem
