20 Most Recent
ASUS X401a 14.1-Inch Laptop Black Intel Celeron B820 1.7Ghz, 4Gb Ram, 320Gb Hdd, Lan, Wlan, Webcam, Integrated Graphics, Windows 7 Home Premium 64-Bit Questions & Answers
Where is the jumper on my ASUS X401A motherboard
You need to take the covers off the bottom of the machine and look in those areas for the jumper. It could be under the ram, near the hdd or the battery and the wireless cards. They don't publish the location because it is an anti-theft feature.
Asus bios reset password on x401a
Check the manual that is on the laptop or type the name of the laptop and the number brand, click enter and your manual will show up, scroll down to find the BIOS of your laptop.
Bios locked on start screen. admin password needed
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type DEBUG and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type: o 70 2e which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type: o 71 ff and hit Enter. Finally type: Quit and hit Enter one last time to quit DEBUG back to the C:\> prompt. Now you're ready to reboot your PC, and press the appropriate key or key combo (look it up in your motherboard manual if you don't know it) to access your BIOS Setup. Youll notice the password is gone. If this fails try typing
At command prompt type debug you will get a - prompt where you can type the following (<enter> means press enter, not type enter*) A <ENTER> MOV AX,0 <ENTER> MOV AX,CX <ENTER> OUT 70,AL <ENTER> MOV AX,0 <ENTER> OUT 71,AL <ENTER> INC CX <ENTER> CMP CX,100 <ENTER> JB 103 <ENTER> INT 20 <ENTER> <ENTER> just hit enter on this line G <ENTER> Q <ENTER> Basic BIOS password - works 9.9 times out of ten If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410
http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps.
PXE-E61 media failure check cable
PXE-E61 Error message showing due to Media cable failure.You have to fix this media cable failure one must return to the BIOS screen at start up. Depending on the model of the laptop, press f1, f2, or delete to enter the BIOS screen (the computer will tell you what keys to press). At the bottom of the BIOS screen, there will be a menu. One of the options should be "setup defaults." By pressing the corresponding key, it will return all of your settings back to how they where originally. Hopefully it will help you
Key popped off
if the key is actually broken, you need to order a replacement, if it is not broken and is still in one piece it should be very easy to reconnect, you just need to find someone who knows how to reconnect keys
User manual for D550MA
Here's a link to Asus's website with a downloadable manual.
http://www.asus.com/us/Notebooks_Ultrabooks/D550MA/HelpDesk_Manual/
