20 Most Recent Sharp R-1870 Convection/Microwave Oven Questions & Answers
I have a Sharp mic/conv oven(Carousel R990-J); it
If the Damper Switch loose contact will couse this problem,try to clean the contact of the damper switch and damper motor .
12/20/2017 1:39:28 PM • Sharp R-1870... • Answered on Dec 20, 2017
The screw in the right filter area that is (approx. 12-13 inches has come loose. I have tried to put in back in place......no luck.Would it be advisable to take oven off the wall? OR, does anyone know
Those screws screw into the support plate mounted onto the wall behind the unit. would guess it is not lining up for some reason or the hole is stripped out. Would have to remove the unit from the wall to inspect the mounting plate and make sure the hole are not stripped out. Lookt at the end of the bolt. do the threads look clean and not pulled or stripped???
10/4/2017 10:03:28 PM • Sharp R-1870... • Answered on Oct 04, 2017
I am looking for the owners manual as well as the carousel
Manual is available for download here ... http://www.sharpusa.com/Support/ProductDetail.aspx?model=R-1870 Carousel tray ... http://www.searspartsdirect.com/model-part/r1870/0958/0123370/50020288/00001.html Item 4-3 about 2/3 of the way down the page
8/2/2016 10:20:02 PM • Sharp R-1870... • Answered on Aug 02, 2016
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/14/2016 7:13:59 PM • Sharp R-1870... • Answered on May 14, 2016
I just had an appliance repair man check my Sharp R-1870 microwave for the 59 second shut off problem. He said it was the main circuit board. Has anyone run into this problem. Everything I google s
I've had a similar problem with a 1983 Sharp Carousel microwave. It turned out to be a faulty door micro switch, the contact didn't stay closed inside it for very long.
2/24/2015 10:44:51 PM • Sharp R-1870... • Answered on Feb 24, 2015
0answers
0answers
No matter what time i put in it cuts off in 60 seconds on a sharp
This sounds like a bad damper switch or motor. Double check the shut off time....... see if it's actually 59 seconds..
When you unplug the unit from the wall for 2 minutes then plug it bad in, you should be able to faintly hear a motor run for a few seconds. This is the damper motor running. This will verify that the motor is operating.....
Also, check the thermistor.
1/27/2015 2:01:05 AM • Sharp R-1870... • Answered on Jan 27, 2015
3answers
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
1/27/2015 1:59:55 AM • Sharp R-1870... • Answered on Jan 27, 2015
Sharp micro counts down 59 seconds and stops
It seems this has been happening over the last few years. I am a retired appliance tech. My 1870 also started the 59 second routine, Also in a motor home. Pure logic. Had to be the board. New board same results. So now I need to run down a parts manual and possibly service manual, and get the damper switch and motor refered to in earlier posts. Changing out the board was fairly simple. Dropping the unit to change out the other components sounds like it will be a tad bit more difficult.
1/27/2015 1:52:10 AM • Sharp R-1870... • Answered on Jan 27, 2015
Microwave oven stops after 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding. The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle. Sharp-made models stop after 59 seconds. See the attached sample drawing for a typical damper assembly. If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer. b27054b.jpg
1/27/2015 1:46:09 AM • Sharp R-1870... • Answered on Jan 27, 2015
HOW DO i REPLACE THE TURN TABLE MOTOR?
Disassemble the set, take out the motor, and replace it with a new one in place.
10/15/2014 1:47:29 PM • Sharp R-1870... • Answered on Oct 15, 2014
How to replace turn table motor
Contact any service technician. http://electronicshelponline.blogspot.com/
10/15/2014 1:46:54 PM • Sharp R-1870... • Answered on Oct 15, 2014
How to unlock sharp stove?
Not super familiar with Sharp Microwave ovens Convection or not, but most microwave ovens can run into at least two reasons that they won't open and both require you to remove the cover over the whole oven - If the door has a push-button to release the door, you could find inside it has popped free of it's pivots and is not lifting up the latches on the door so you can open it, or is has actually snapped that latch. The other thing I have seen more on Panasonic microwave ovens and again moreso on the newer Inverter ovens, is that the latching assembly inside is attached to too thin a piece of metal and the metal actually bends - now your door and it's latching assembly and switches don't line up properly. In that case you will still need to remove the cover and do your best to realign the switch assembly with the front of the microwave so that the door can click in and out easily.
5/29/2014 3:00:36 AM • Sharp R-1870... • Answered on May 29, 2014
Sharp R-1870 Convection/Microwave Oven Logo
151 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
door snaps when open fully
  • Microwave Ovens
