20 Most Recent
Kohler C3-200 K-4709-96 Biscuit Elongated Toilet Seat with Bidet Fun Questions & Answers
K-4709 toilet seat with bidet
I would check to see if you in fact have power going to the pump itself,, you might just have a bad water pump or a bad switch. use a volt meter to trace voltage flow.
c...
Toilet does not flush down contents.
This seems to be a case of blockage within the toilet. Check the
Flushholes under the inside-rim of the toilet. they might be partially blocked by debris or deposits. If so, a Wire-Clotheshanger will help.
If the Blockage is in the drain, a Handauger might be helpful to push
blocking objects through or retrieve.
Waterlevel in the Toilet-tank could be too low. It should be about 1"
below the top of the Drainvalve in the middle of the Tank.
Toilet does not flush strong enough to take down feces in bowl
You need to do 2 things. Take the lid off and check that the water level is up to the fill line, if it is you need to adjust the flapper. If it's not back the screw out on top until it is. Their should be a cylindrical piece of foam on the chain going to the handle. You need to pull off the retainers and move that foam closer to the flapper thus dumping more water in each flush.
Please rate this solution-
I have a Kohler commode about 1 1/2 yrs old. When
Does it have bll **** on it?That means a long brass rod with a ball on the end.If it does then gap it with both hands and with the hand next to the ball push down a little ways and keep doing this until the water stops running.If you have a fluidmaster brown or black the little wire on the side of you will see a little metal piece squeezed it and down and the should stop.
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
