20 Most Recent
Panasonic TC-P42X5 42" 720p Plasma HDTV TCP42X5 Questions & Answers
Have a panasonic plasma p42x5 the screen will not come on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2/16/2016 8:30:39 AM •
Panasonic...
Answered
on Feb 16, 2016
Panasonic viera tv manual
This can be a deffective panel. If it is defective, it usally takes about an hour of being on before the sound can be noticed. It could also be leaky diodes which is what i would hope for if it were my tv. Can you explain in more detail of how long it takes to be noticed and etc....
Regards,
Joe Van Buren
8/12/2014 9:05:01 PM •
Panasonic...
Answered
on Aug 12, 2014
Where is the internal fuse? How do I replace it?
It sounds that either you can't locate it or replace it, or repair this set. Please contact any service technician. Mind it; this is a Plasma display, and not a toy as you things. Products powered by electricity
should be serviced or repaired only by experienced professional technicians.
Any attempt to service or repair the product by anyone else could result in
serious injury or death. If
you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact
the nearest service centre. If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
10/27/2013 6:52:41 AM •
Panasonic...
Answered
on Oct 27, 2013
Power light red no sound no picture
Red light is standby, it turns green when TV IS turned on. If the red light is flashing then there is a problem and number of flashers are a code to indicate a fault type.
9/21/2013 10:51:25 AM •
Panasonic...
Answered
on Sep 21, 2013
No power to tv
I would suspect bad capacitors on the power supply. They drain when left unplugged from the power source and then when power is restored the weakcapacitors cant recharge and the set wont power up.
2/9/2013 4:35:55 PM •
Panasonic...
Answered
on Feb 09, 2013
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
