20 Most Recent
Samsung Pn51d450 51 720p Plasma Tv pn51d450 Questions & Answers
TV trys to turn on about 3 times then does not turn on at all.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Samsung Plasma..clicking pn50a400c2dxza
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size.
Pull up older posts. Surf the site with patience.
