20 Most Recent Toshiba CT-90233 Remote Control Questions & Answers
Probably needs the caps replaced in the power supply but I would get an engineer to tackle this job unless your confident at soldering.
Toshiba CT-90233... | Answered on Dec 01, 2014
Use code search on your Westinghouse URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Toshiba... | Answered 3 days ago
I may be guessing, but here goes. Make sure all the ink cartridges are seated. In Properties, got to Advance - have your settings checked off as follows: Spool print documents so program finishes printing faster, Aart printing after last page is spooled.
Clean the heads in printer, maybe a sllightly dirty cartridge opeining.
Other than above, I don't really know the correct solution.
NOT A CLUE SORRY
Toshiba... | Answered on Nov 25, 2019
go into set up and select cable then channel search and use 3 or 4
Toshiba... | Answered on Nov 23, 2019
DIODE or sensor in the unit. Not user serviceable
Toshiba... | Answered on Nov 22, 2019
There are a couple of things that could cause this. One is a bad diode in the power supply and the other is a bad sensor in the playback unit near the head. Neither one is job for anyone that has no experience in electronic repairs.
If u need to see online on usinig internet on your pc it is easy. For solution check the below link >>> http://w.atch.me/3qny1s
Toshiba... | Answered on Nov 21, 2019
Shouldn't matter what the OS (operating system) is. What you need to do is to make sure you convert the movie to proper format which would allow you to view on DVD player after burning. Usually you need a seperate software. Your DVD player should say what formats are compatible. Usually listed on unit or in manual. Avi is a great format but when you burned it to DVD your computer probably created a Data Disk. Which would make it unreadable by DVD player. Check to make sure you are able to convert to format that's readable by your player.Good Luck
Toshiba... | Answered on Nov 14, 2019
It is out there, that if you have internet enabled on the Toshiba BD player, did you need to stop or disable the internet capability.
Toshiba... | Answered on Nov 10, 2019
the power led may be flashing a code you can google.
My Panny will flash the power LED when there is a problem. Well, for many problems anyway. Observe the sequence like 7 and 3. I do not know if the Toshiba has that feature. If not, the issue is most likely power, HOWEVER, any board could be at fault since it powers up then shuts down. An excessive load on another board could be shutting it down. A fault on the PS board itself could also be shutting it down.
Toshiba... | Answered on Nov 07, 2019
Toshiba CT-90233 Remote Control Logo
2 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
reset toshiba tv model ct 90233
  • Televison & Video
