20 Most Recent
Ricoh Aficio MP2352 Copier Questions & Answers
Why toner spills ?
when toner spills it could be that the seal between toner tray/harper/ hopper is not working properly, it could also be developer inside the drum that is worn down, if you page/print has a slight grey background then replace the developer, you will need a qualified technician for this as there is settings that need to be done after developer replacement
How to Remove error code SC865
Hi there
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
It details the SC86? as hard disk or disk controller problems with SC865 being specifically the hard disk. I therefore doubt if you will be able to get rid of this fault without replacing at least the hard disk and possible the disk controller board as well.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Settings for fax machine
you need to be more specific, there are lots of different settings for a lot of different areas/ reasons. More info please
Drum is getting to hot
the drum is situated right below the fuser/fixing unit which stays at a high temperature during use, after a while it will warm up the drum as well, you are not supposed to touch the drum, if you feel it is getting abnormally hot, then contact a qualified technician to investigate
After print no document
re-install print driver on PC and check network/usb connection, also try restarting your printer by switching off for at least 10 seconds, then on again
Ricoh 2352 will not scan to email
could be alot of reasons for not scanning to e-mail, need more detail but here are a few common problems/settings. Go to counter/menu, then system settings, then go to "file transfer", add your smpt server name/IP and then smtp authentication if you have a smtp password, then scroll down to administrator e-mail address and put it in, then scroll down to auto add sender name and swithch it on, then go to "pop before smtp" and swithc it off, also swith off "max e-mail size"
Cutting off top of page
check the paper orientation, change it to landscape/ portrait and try printing again, if it does not work then ask a technician to check your drum and developer
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
