20 Most Recent Ricoh Aficio Mp-1600 Copier Questions & Answers
Your gears in the Development unit are probably worn out and needs to be replaced. Machine will not be able to add and cycle toner if these gears are worn out.
Ricoh Aficio... | Answered on Aug 03, 2016
This is a Ricoh error code. There is a laser unit synchronization error with the drum unit. I would take out the drum unit of the Ricoh and reseat it to see if that's the problem. You may have a bad drum or a laser unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer copier maintenance repairs, copier printer leasing and supplies.
Ricoh Aficio... | Answered on Apr 08, 2016
Having problems finding your error code. Here is a complete list of all codes for your printer: http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP1600
I do find the error code for a different Ricoh model (Aficio 1018).
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%201018
Please verify your model number and error code.
Ricoh Aficio... | Answered on Apr 21, 2015
Clean the toner hopper and check the dev gears on the drum unit. Usually thats the problem why its not loading toner.
Ricoh Aficio... | Answered on Sep 03, 2014
try with new inkcatridge
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
Ricoh Aficio... | Answered on May 05, 2014
need need new tires in tray 1
Ricoh Office... | Answered on Jan 06, 2020
SC-990 - Communication problem between BICU and input output board or software performance error.
I would suggest contacting Ricoh customer service.
Ricoh Office... | Answered on Dec 27, 2019
From things I have read about this error code, it could be happening because of using compatible sublimation inks which is causing this problem.
Check out the following link:
https://www.dyesubforum.co.uk/vbforum/archive/index.php/t-13457.html
Ricoh Aficio Mp-1600 Copier Logo
8 questions posted
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
add toner problem
  • Office Equipment & Supplies
