20 Most Recent Philips Philishave Cool Skin HQ6760/HQ 6761 Questions & Answers
Help please. My Philips coolskin
When the shaver head light flashes, this indicates that the heads should be changed. You will need the specific model number written on the shaver to select the correct type heads
6/23/2017 2:45:09 PM • Philips... • Answered on Jun 23, 2017
Hi, I'm Looking for a Philips 8000 Series Razor Charger Stand.
You will find this item at shaveroutlet.com. Always be sure to match your specific model number to the list of compatible models to ensure you are ordering the correct item. Norelco Philips 8000 Series Cool Skin Charging Stand
3/29/2016 5:06:41 PM • Philips... • Answered on Mar 29, 2016
How to get replacement heads for philishave cool skin HQ6761
Compatible blades can be found at shaveroutlet.com using the link below http://shaveroutlet.com/philips-norelco-hq7-gentlecut-shaving-heads.html
8/12/2014 4:17:03 PM • Philips... • Answered on Aug 12, 2014
0answers
Hand Book
Be the first to answer 3/24/2014 3:12:34 AM • Philips... • Posted on Mar 24, 2014Be the first to answer
0answers
0answers
My philipshave coolskin shaver doesn't
Your battery pack is probably dead and needs replacing. You will find the correct battery for model 5605X at shaveroutlet.com. See link below for item and also scroll down item page for installation tip videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
8/14/2011 7:50:12 PM • Philips... • Answered on Aug 14, 2011
MY DAD DROPPED HIS PHILIPS
Sounds like one of the heads are damaged or something is not put together correctly causing it to jam. Watch the video below to make sure that you have the heads in correctly.
http://www.shaveroutlet.com/philips_norelco_heads_replacement
If you have everything in correctly and it stll jams, one of the heads is likely damaged. You can remove them individually and turn the blade clockwise inside the comb with your fingers. Each should turn freely. If any will not turn, you will need to replace them. You will find replacements for 7300 series shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
5/4/2011 5:16:26 PM • Philips... • Answered on May 04, 2011
I forgot how to
You will find an instructional video at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq167-cool-skin-replacement-heads-p-247.html
2/8/2011 2:18:51 AM • Philips... • Answered on Feb 08, 2011
0answers
I am looking for an electric charger for my shaver
Why dont you try and google it. Also go to where Kenyans buy & sell
http://www.uzanunua.com/
am also in Kenya
6/5/2010 10:43:56 AM • Philips... • Answered on Jun 05, 2010
Hi My Philips Coolskin shaver has locked with
Hold down the on/off button for 6 seconds
3/22/2010 11:28:01 AM • Philips... • Answered on Mar 22, 2010
Charged up but seems jammed
soak your blades in a boiling solution for a couple of minutes.
11/2/2009 3:27:09 PM • Philips... • Answered on Nov 02, 2009
Charged for approx. 6 hours then wouldn't work
I copied this from the Philips website... this took me FOREVER to find! Their site isn't the easiest to find products on...
"Insert the small plug into the shaver and put the powerplug in the wall socket. When you charge the appliance for the first time or after a long period of disuse, let the shaver charge for at least 16 hours. Remove the powerplug from the socket and the small plug from the shaver as soon as the batteries have been fully charged. Ignore the charge indicator when you charge the batteries for the first time. The batteries are completely new and need to be charged longer than the time indicated by the charge indicator to ensure that the back-up capacity is fully charged as well."
I hope this helps. Please remember to rate my help! I would greatly appreciate it!
4/26/2009 4:24:44 PM • Philips... • Answered on Apr 26, 2009
BROKED THE head
I stock these parts at my store> I can shp them to you. Please call 1 888 643 9806 and ask for Action Mike.
2/11/2009 6:20:57 PM • Philips... • Answered on Feb 11, 2009
3answers
Philips cool skin shaver fault
The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
2/5/2009 8:03:27 AM • Philips... • Answered on Feb 05, 2009
Philips Philishave Cool Skin HQ6760/HQ 6761 Logo
30 questions posted
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Health & Beauty
Most Popular Question
charged approx 6 hours wouldnt work
  • Health & Beauty
