20 Most Recent
Oster 76076-010 Hair Trimmer Questions & Answers
Clippers have suddenly stopped cutting
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Defective power cord on CHI GF1001 flat iron straightener
My wife's flat iron had an issue with losing power while moving the iron around. I at first thought it was a cord issue, but before tearing into the cord, I disassembled her iron by popping off the two "CHI" covers from either side of the fulcrum. This revealed a screw which when taken out allows you to push the pin out releasing the handle's spring mechanism. Once opened, you can see the power-swivel thing-a-ma-jig and I saw the positive (red) wire had come off of the little flat board mounted on the swivel piece. I simply re-soldered the wire back on to the flat board and BAM!
Good as new!
How to sharpen oster clipper
In order to sharpen these blades you must first dis-assemble them (paying particular attention to the way everything fits together), Next you need to get a piece of glass or something as flat as possible and tape a sheet of 180 grit emery paper with the rough side up. Then you put the upper blade on the emery paper wih the flat side down and stroke it back and forth in a straight line at least 100 strokes each way. Turn the blade over and examine the surface with a magnifying lens to see if you have honed the blade flat all the way across. Next turn the blade 90 degrees and again stroke the blade back and forth in a straight line. Turn the blade over and examine again to see if you have removed all the first series of strokes and the new set is flat from edge to edge. If so then put that blade aside and do the same thing to the lower blade until it is flat across and up and down. After reaching this stage you need to remove the 180 grit paper and go up to 230 grit paper and repeat the whole process. After completing the second stage you progress to 400 grit paper and repeat once again..
Make sure you keep the blades straight so the hone marks are up and down and from side to side and you should have an almost razor sharp cutting tool. Also DO NOT USE SAND PAPER only emery paper or cloth. I know this sounds like a lot of work but after you've done it a couple of times you can whip out a blade in about 20 minutes.
