20 Most Recent Singer 9960 - 9960 Quantum Stylist Questions & Answers
2answers
Singer 9960 automatic thread cutter not working
I'm looking for a solution to why the thread cutter isn't working. It just pulls the thread into a knot and jams the bobbin case. I was hoping for an answer here but the answer had nothing to do with the question!
9/7/2022 7:41:46 PM • Singer 9960 -... • Answered on Sep 07, 2022
How do I correct excessive noise and rattling of bobbin in Singer Quantum Stylist 9960 model sewing machine?
Do NOT oil!!
You need to have the bobbin case replaced. I had mine replaced under warranty.
12/24/2019 7:42:03 PM • Singer 9960 -... • Answered on Dec 24, 2019
How do I do a factory reset on a Singer Quantum Stylist 9960?
Here is a link to the instruction manual, if you can do a reset it will be in the manual, if not then it is not an option http://www.singerco.com/uploads/download/1242_9960_esf.pdf
11/4/2018 2:10:19 PM • Singer 9960 -... • Answered on Nov 04, 2018
Upper thread keeps breaking
I have this problem too. I have traced the problem to a design fault in the thread path. The thread wares a groove in the casing and snaggs the tread causing it to stretch and break. When it breaks it releases so it took me a long time to locate this problem. I have just contacted Singer and am awaiting their response. (See photo) it is my belief that this problem is responsible for needles snapping and a host of other issues. I hopes this helps. It should be an easy fix, it just requires a metal plate to cover the grooves cut by the thread. 6533e83e-3aee-4d3b-af4d-19fa59f519d5-0qus2ei5i2opofa4xilq0h3i-1-0.jpeg
10/8/2018 7:05:40 PM • Singer 9960 -... • Answered on Oct 08, 2018
What is the most likely cause of a singer 9960 that powers on but won't start? Both foot pedal and button tried a few seconds after each hear a beep and screen says to release button/pedal.
This is a sign that your pedal may need to be repaired or replaced. Cheers, Embroidery Services San Diego, CA
10/31/2017 6:21:49 AM • Singer 9960 -... • Answered on Oct 31, 2017
Troubles with the bobbin tension on the singer quantum 9960
the small flat spring on the bobbin holder under which you pull the thread is the tension setting for bobbin thread it extremely delicate and just a partial turn of the screw that holds that spring in place has a large influence on the tension mostly problems here are that the needle tension is insufficient and causes the problems
10/2/2016 4:21:45 AM • Singer 9960 -... • Answered on Oct 02, 2016
When I try to sew, my sewing machine stitches backward instead of forward. Can you tell me why?
the movement is set in reverse change the setting to forward
5/12/2016 4:18:11 AM • Singer 9960 -... • Answered on May 12, 2016
The bobbins are breaking while trying to load with the thread i have broken 4
15 J bobbins not just 15
12/26/2015 8:35:53 AM • Singer 9960 -... • Answered on Dec 26, 2015
Can i replace a fuse if its just a fuse. without having to drive two hours to a repair center and wait a month and pay and arm and a leg for a fuse
Yes if you know how to locate the fuse and to dismantle part of the machine if need be to access it.
12/25/2015 12:39:49 PM • Singer 9960 -... • Answered on Dec 25, 2015
Automatic thread cutter is broken
9/6/2015 12:40:18 PM • Singer 9960 -... • Answered on Sep 06, 2015
Flower stitch not working
9/2/2015 2:55:50 AM • Singer 9960 -... • Answered on Sep 02, 2015
Singer 9960 - 9960 Quantum Stylist Logo
45 questions posted
Top Singer Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Singer Iron Expert? Answer questions, earn points and help others
View Most Popular
Singer Irons
  • Singer Irons
Most Popular Question
upper thread keeps breaking
  • Irons
