20 Most Recent Daewoo DW-160C Washing Machine, 8 Kg Capacity, Rust proof plastic base and steel cabinet, High speed spin dryer, Spin dryer safety system, Powerful water flows from big pulsator, Normal & strong wash selector, Spin rinse system, Two lint filters DW160C DW 1 Questions & Answers
Waar kan ek motor herstel of koop vir Daewoo air injection 9020 teen n bekostigbare prys
Daewoo Washing... | Answered on Sep 01, 2019
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Daewoo Washing... | Answered on Jun 13, 2019
remove it and check for anything that is jamming it if good u can make up a lead to test and see if it runs
Daewoo Washing... | Answered on Apr 22, 2019
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Daewoo Washing... | Answered on Apr 05, 2019
H3
Overheating dryer heater element detected. A fault has been detected with the dryer side heating.
  • Check fan motor is clear and unobstructed
  • Check wiring
  • Check dryer heating sensor
Daewoo Washing... | Answered on Jan 27, 2019
Daewoo DW-160C Washing Machine, 8 Kg Capacity, Rust proof plastic base and steel cabinet, High speed spin dryer, Spin dryer safety system, Powerful water flows from big pulsator, Normal & strong wash selector, Spin rinse system, Two lint filters DW160C DW 1 Logo
7 questions posted
Top Daewoo Washing Machines Experts
Marvin
Marvin
Paul Bade
Fahr Quad
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Daewoo Washing Machines
Most Popular Question
sorry posted question about washing
  • Washing Machines
