20 Most Recent
LG WT4870CW 4.5 Cu. Ft. Top Load White Washer Questions & Answers
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
I have got a front
Is the washing machine giving off a hot machine oil smell or making a grinding noise when the tub is turning? I've had to replace the drum bearings several times on LG front load washers. The first sign that the bearings are going are loud noises when the drum is spinning and eventually the hot machine oil smell. The bearings can be replaced but they usually last only 6 months to a year. The bearings are put on with a press at the factory and unless you are very accurate, you won't be able to get them on exactly straight and they will wear out quick.
10/27/2023 10:07:56 PM •
LG Washing...
Answered
on Oct 27, 2023
