20 Most Recent Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Questions & Answers
2answers
JAMMED, WON''T UN-JAM WITH BROOM HANDLE.
Here is a tip that will help you...
http://www.fixya.com/support/r4062599-garbage_disposal_clogged_or_jammed
heatman101
10/15/2018 11:11:55 PM • Ace Hardware... • Answered on Oct 15, 2018
Badger 5-81 motor buzzing, blades spinning, won't grind
Replace the whole thing. They are not that expensive and are easy to replace. The issue could be bad motor part or the shaft came loose from the grinding disk.
7/9/2017 10:51:12 PM • Ace Hardware... • Answered on Jul 09, 2017
Water flows out of garbage disposal vent when ever we use the dishwasher
Most likely the whole thing needs to be taken apart and cleaned, not just the disposal, but the plumbing as well. I have often had to do this for others. Very often the problem has been people put things in the disposal that plug up the plumbing, like eggshells, bananana peels, and other fruits & vegetables that readily plug the system. I have had to take such apart too many times to count. Oh, yes. If your dishwasher empties into the disposal ( that is normal) you may find your 2 choices are to repair or replace the disposal, or remove the disposal all together and hook the dishwasher drain directly to the plumbing. God bless your efforts.
7/4/2017 7:53:31 PM • Ace Hardware... • Answered on Jul 04, 2017
We are getting granite and
I'm not sure what bolt you are talking about.
The sink strainer attaches to bottom of sink with 3 bolts.
If bolts breaks, you can substitute ordinary 1/4" hex bolt.
If a bolt is broken off inside something metal, then you can drill a small hole in the broken bolt.
Then remove bolt using a screw extractor available hardware or auto parts store.
You can drill out the bolt, and then re-thread the hole.
I suggest you take the part in question to hardware store.
I used to work hardware/home-center, and those guys can get eyes on the job and offer best solution.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
1/22/2017 3:15:24 AM • Ace Hardware... • Answered on Jan 22, 2017
Smoke is coming from the bottom of my in-sink-erator
Make sure the insinkerator is spinning. If not, it will burn out if the motor if the built in breaker does not pop. Using the tool that comes with unit loosen the spindle so it turns. Then turn on and hope that you did not burn out any of the windings. If you did, it will work but use too much current, overheat and possibly trip the breaker. If motor has been damaged, then replacement is in order since the part cannot be ordered separately.
7/24/2016 3:33:06 PM • Ace Hardware... • Answered on Jul 24, 2016
2answers
The garbage disposal turns on,
Use wood stick or broom handle and see if blades rotate freely.
If blades are stuck, then use wood stick to wedge free the blades.
If blades rotate freely and disposal doesn't work, then disposal has gone bad.
Install new one.
For replacement instructions:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
2/12/2016 2:28:12 AM • Ace Hardware... • Answered on Feb 12, 2016
Garbage disposer drain pipe is lower than the p-trap
Sorry you are doomed. The only other way to install is to have a plumber come back out and lower the drain in the wall.
2/6/2016 12:16:39 AM • Ace Hardware... • Answered on Feb 06, 2016
2answers
My mother-in-law's insinkerator shakes violently
You cant break stainless steel cutter blade, welded parts and steel ball bearings with water mellon rinds.
Even a metal fork should not break a garbage disposal ... the fork will wedge against the side wall and cause cutter blade to get stuck. Once the fork is removed, no damage is done.
If insinkerator is shaking, then either a bearing has rusted out, or the shaft has finally worn out.
The stainless cutter blade is permanently attached to a steel shaft that goes into the sealed bearing. If the cutter weld is broken, then the disposal will wobble. If the bearing wears out, then the steel shaft will wobble. If the steel shaft is worn down at the bearing, then the cutter plate will wobble. A tiny bit of wobble will cause the disposal to shake. A brand new disposal will vibrate.
Check date of purchase receipt.
Amazon shows warranty is 2 years:
http://www.amazon.com/InSinkErator-Badger-Food-Waste-Disposer/dp/B00004U9JO/ref=sr_1_3?ie=UTF8&qid=1303015273&sr=8-3
If disposal is 3-5 years old then that is a short lifetime for a solid product like the 1/2 HP.
If disposal is 5-8 years old, that's a good run. 8-12 years is very good.
I wrote tips for replacing disposal from days when I worked apartment maintenance:
We replaced disposals every 6-7 years. Some never wore out. Others went bad right away.
12/9/2015 8:29:22 PM • Ace Hardware... • Answered on Dec 09, 2015
I just noticed that my insinkerator Badger 5-75 is
If it's pretty new (less than 2 years) you might be able to get free service or free replacement. Apparently this is a common failure with this model. If it was me, and out of warranty, I would spring for the $100 or so and get a new one.
10/17/2015 4:05:01 PM • Ace Hardware... • Answered on Oct 17, 2015
Dishwasher not draining completely after new garbage disposal installed
If you hooked up the drain to the disposal directly there is no vent in the line. Use the air vent on the sink to connect the dishwasher drain hose. If there is no air vent, then you'll have to install one in the sink.
7/15/2015 4:20:14 PM • Ace Hardware... • Answered on Jul 15, 2015
Where is packing plug located on garbage disposal
The inlet to hook up a dishwasher drain has a knockout plug in it. Use a screw driver or a punch and hammer to remove it .
7/15/2015 4:17:41 PM • Ace Hardware... • Answered on Jul 15, 2015
Garbage disposal makes loud noise, nothing stuck, blades turn freely
Bearings in the motor are worn enough to allow the grinder plate to rub against the side of the chamber.
7/15/2015 4:12:36 PM • Ace Hardware... • Answered on Jul 15, 2015
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
7/15/2015 4:11:07 PM • Ace Hardware... • Answered on Jul 15, 2015
Nail fell into insinkerator, doesn't turn,jambed. can I get this out
Use the allen wrench that came with the disposer or get a new one that will fit in the center hole on the bottom of the disposer. Using that tool you turn it back and forth until the nail loosens enough to remove it.
7/15/2015 4:04:26 PM • Ace Hardware... • Answered on Jul 15, 2015
Model 81
Roto rooter the drain pipe in the wall. It's plugged. The water goes up the vent pipe to the roof that's why the water comes back in the sink when you shut off the disposer.
7/15/2015 4:02:05 PM • Ace Hardware... • Answered on Jul 15, 2015
I put flowers down my garbage disposal. Now it won't drain.... What do I do?
Disconnect the drain pipe where it connects to the disposer and remove the P trap where the pipe goes into the wall to remove the blockage .
7/15/2015 3:58:59 PM • Ace Hardware... • Answered on Jul 15, 2015
How to fix a garbage disposal from the bottom?
There is a hole in the center stick your Allen or wrench that came with it in the hole and wiggle it till you get it to turn free remove wrench and turn on. That should do the trick
7/8/2015 10:21:39 PM • Ace Hardware... • Answered on Jul 08, 2015
2answers
I ran insinkerator last nite. This morning it
Unplugged the insinkerator and hit the reset button and then plugged it back in.
3/9/2015 4:13:54 PM • Ace Hardware... • Answered on Mar 09, 2015
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
734 questions posted
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ace Hardware Electrical Supplies
Most Popular Question
badger 5 model 5 81 not
  • Electrical Supplies
