20 Most Recent
Luminox Navy Seal Dive 3204 Wrist Watch Questions & Answers
I cant pull out the date/time pin on my luminox
On some watches - scuba usually - the crown has a rubber seal and that seal is engaged when the crown is screwed to the case. If your watch is like this, you need to unscrew the crown before you can pull out the stem.
Twist the crown in a counterclockwise direction several turns. You will be able to tell when it is completely unscrewed because youwill feel spring tension. Pull out the stem to set the watch. When you finish, push the stem back in.
Push against the spring tension and carefully thread the crown back onto the case.
That should do it.
