20 Most Recent liftmaster Chamberlain Garage Door Opener Transmitter 300MC Questions & Answers
2answers
HBW1241 Can Not Change Remote Battery
I have the same remote. You need to wedge in a flat-head screwdriver. Push it into the plastic and turn. This will release it from the catches. Now I just have to find out where to get the flat 1/2" lithium battery to replace it.
9/16/2022 5:21:40 PM • liftmaster... • Answered on Sep 16, 2022
2answers
Lift-Master 1260, circa 1993. Today it won't open or close.
29 years is along run on an opener. Personally I would replace it and not spend any money trying to repair it. You can try and find a control panel, or buy a new opener for $200.00 at HD. you can leave track in place replace rollers from new opener box.
8/31/2022 7:05:49 AM • liftmaster... • Answered on Aug 31, 2022
I have a lift Master Model 2280 garage door
Sounds like loose connections. Unplug, remove the cover and be sure all connections are tight and secure. While doing this be sure there are no burnt connections or burns on the PCB. Replace cover, plug in and it should be OK.
10/2/2021 3:12:10 AM • liftmaster... • Answered on Oct 02, 2021
I have a Liftmaster Elite
Yes, follow the directions with your liftmaster, that should solve the problem.
10/2/2021 3:10:17 AM • liftmaster... • Answered on Oct 02, 2021
I have a Genie garage door opener. ONLY DURING COLD WEATHER does it act up. When I close the garage door it goes to the completely closed position and retracts. I have adjusted the limit switch and it
It is probably the lubrication in the rollers. You should lubricate them and make a small adjustment to the torque sensor. When it gets cold the lub gets stiff. The torque sensor will detect this and open the door, a safe position.
10/2/2021 2:55:53 AM • liftmaster... • Answered on Oct 02, 2021
2answers
How do I uninstall my
When you say sensors, are you talking about the photo-eye that checks if obstruction is in path of garage door?
1) You can buy sensors for $20-30. They seem generic
2) The new openers may be set up so by-pass is not an option.
Solution: In that case, you can move sensors above the garage door and put them face to face to see if that helps.
3) The way the sensors work is this. One side produces beam of light. Other side receives light. The receiver keeps a circuit closed at all times when light is received. If no light, then the circuit opens up and an electronic part interprets the lack of signal and turns off opener.
Solution: one side produces light. It does not have a switch. The other side has the switch. You can disconnect (or cut) a wire see which side has the light. The other side has the switch ... cut the 2 wires on the side with a switch, cap them off, and then see if opener works. Next twist the 2 wires together and see if opener works.
4) Fall-back position: Mark your wires and you can put it back the way it was.
12/1/2019 3:55:41 AM • liftmaster... • Answered on Dec 01, 2019
Liftmaster garage door opener will not operate
is the remote coded correctly, fuse on the remote board blown.or faulty remote board
9/8/2019 10:46:12 PM • liftmaster... • Answered on Sep 08, 2019
3answers
Does any knows about professional garage door repair provider of Miami?
Get a best garage repair provider from http://www.aqualitygaragedoors.com/. I recently hired them and find them best in Miami.
1/3/2019 12:27:58 AM • liftmaster... • Answered on Jan 03, 2019
3answers
Garage door will open from remote or car;but wont close,only closes by inside wall unit
Something could be blocking the electric eye.they are down at ground level on both sides of the door
12/29/2018 1:08:02 AM • liftmaster... • Answered on Dec 29, 2018
2answers
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the ma
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
12/29/2018 1:06:04 AM • liftmaster... • Answered on Dec 29, 2018
I can't seem to get my remote to work with the
batteries in remote maybe?
2/3/2018 9:05:41 PM • liftmaster... • Answered on Feb 03, 2018
Hi, when I replaced my
hi check that the door is free from stifness
1/3/2018 2:09:46 AM • liftmaster... • Answered on Jan 03, 2018
I do have a lift
http://support.liftmaster.com/articles/How_To/LiftMaster-receiver-and-remote-compatibility-1484145638635 I don't believe a universal remote will work. Here is a link to compatibility
11/27/2017 4:48:51 PM • liftmaster... • Answered on Nov 27, 2017
Chamberlin Liftmaster keypad entry does not worek
It will only take a 4 digit program code. After you program the code, and then enter that code to open the door, hit an additional number on the keypad. Some need the additional digit to act like an 'enter' key.
10/3/2017 3:04:18 AM • liftmaster... • Answered on Oct 03, 2017
I have a Liftmaster Professional
Disconnect power to the opener! Then, with a dental tool or small screwdriver scrape off any corrosion etc from the contact in the center of the socket. Also note if it is lying flat against the bottom of the socket. If so, gently lift the center so it has some spring retention and rises up off the flat bottom of the socket.
9/23/2017 2:42:40 AM • liftmaster... • Answered on Sep 23, 2017
Product Lift Master Professional Line 1/2
Check alignment of the obstruction sensors .... they shoot a light beam across the doorway about 6 inches above the floor. One is mounted on each side of the door track near the floor.
9/23/2017 2:30:16 AM • liftmaster... • Answered on Sep 23, 2017
My Liftmaster Formula 1 opener has stopped receiving signals. The wall switch operates the door, but remotes will not. Our 2nd door opener was east to program a new remote.
This sounds like a similar problem that I had. The circuit board on the garage door motor has a capacitor that goes bad and this prevents the remotes from working. You can either buy a replacement circuit board online (for around $80 if I remember) or if you can solder, simply replace the capacitor for a few dollars. I answered a similar question on this site before after I went through the process. There are more details there. The capacitor in question was close to a heat producing component and over time it cooks.
9/15/2017 12:24:37 AM • liftmaster... • Answered on Sep 15, 2017
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
689 questions posted
Top liftmaster Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • liftmaster Electrical Supplies
Most Popular Question
lift master 41a5021 1m 315 remotes
  • Electrical Supplies
