20 Most Recent
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Questions & Answers
ML600 won't turn off
The clock module for power pack is not sold separately.Set timer to auto using override knob so lights are on, then plug power pack into cheap timer.Check outlet with circuit analyzer.Try connecting power pack to another outlet.Copy following link for warranty information, tips to help power pack last longer, links to trippers, troubleshoot, etc.http://waterheatertimer.org/Malibu-power-pack-stopped-working.html If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
http://waterheatertimer.org/Malibu-power-pack-stopped-working.htmlReason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.Add a comment and attach photo as needed. If you need further help, I’m available over the phone at
