20 Most Recent KitchenAid KGRT607 Gas Kitchen Range Questions & Answers
KitchenAid Gas Range Model KGRT:
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
11/26/2019 9:47:57 PM • KitchenAid... • Answered on Nov 26, 2019
My beep quit! Beep used to work when the oven came
We have a Kitchenaid Superba gas stove and the beeps would not sound. We thought the control panel was shot, but we have a WONDERFUL repair man. Here was his re-set.....open oven door, push the cancel button, push stop-time button and hold that button for about 5 seconds. When the beep sounds let go and the panel is re-set. WOW!!!!
3/24/2019 6:55:10 PM • KitchenAid... • Answered on Mar 24, 2019
0answers
Oven control panel does not light when oven turned on
If oven works, it's a problem with electric circuit
6/2/2015 4:41:44 PM • KitchenAid... • Answered on Jun 02, 2015
0answers
CAN'T SET OVEN HIGHER THAN 250DEG.F, DISPLAYED ERRO AND THEN START APPEARS. OVEN WILL COME ON, 250DEG. F MAX.
It sounds like you got the electronic oven control to expect temperature settings in Centigrade (Celsius) instead of Fahrenheit. Check your owner's manual to find out how to change it back to Fahrenheit. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1/27/2015 5:11:45 AM • KitchenAid... • Answered on Jan 27, 2015
0answers
0answers
F2e3
Be the first to answer 3/30/2014 4:17:39 AM • KitchenAid... • Posted on Mar 30, 2014Be the first to answer
Oven not setting temperature
need more info does it even get warm if it does but not to temp needs temp sensor if it wont light needs ignitor
3/27/2014 3:34:01 AM • KitchenAid... • Answered on Mar 27, 2014
0answers
4answers
Kitchenaid KGSA906PSS00
I recently encountered this issue after trying "self clean" on my KitchenAid oven for the first time. I wish I had read these forums and simply avoided the feature. KitchenAid was, of course, completely unhelpful since my warranty was expired. This is the first they've heard of the problem; perhaps search engines are prohibited within the KitchenAid community and they are unable to view the complaints of thousands of other customers as I have... but I digress.
The solution was straight forward: Don't worry about the locked door for now and pull the oven away from the wall. Safety first: unplug your oven and turn off your gas valve. Now remove the back panel. There is a sheet metal strip near the top of the oven that must be removed before the back panel comes loose. With the back panel removed, look for a circular device with a blue and white sticker on it and the part number: 8300802. This is a thermal fuse that blows when the oven gets too hot (apparently "too hot" is a subjective measure as normal operation during self clean will cause this issue). You can check it with a multimeter if you have one... a failed fuse will have a high resistance. To ensure this is your only issue and to immediately unlock your door, adventurous types can bypass the fuse by connecting the two wires that connect to the fuse and hold them together with some electrical tape. WARNING: never operate your oven in this manner. This is a quick test to verify resolution of the issue; not a permanent fix. Apply power to your oven and presto, your door will unlock and your front panel will illuminate.
Now, use the aforementioned search engine KitchenAid has never heard of and search for your new fuse: 8300802. I got mine for $34... you can probably find it for cheaper but my patience was wearing thin by the time I got to ordering a replacement part.
Oh, and one last step: never ever under any circumstances use the self clean feature. Do not take the easy route like I did: get your Brillo Pad and your Easy-Off and get dirty, you lazy bum.
5/21/2013 11:01:56 PM • KitchenAid... • Answered on May 21, 2013
I have a Kitchenaide KGRT607HWH6 the oven gets up to temperature and then displays the F7:E0 code and shuts down What is this error code?
The error code "F7:E0" means "Invalid latch switch reading".The first thing I would do is check the interlock switch on the door latch and the door latch itself (the door latch assembly is located on the back of the range). The interlock switch must be closed when the door is locked.If there is nothing wrong, then check the wires from the switch to the control board.If wires are fine then replace the control board.Here is the interlock switchHere is the oven lock assemblyHere is the control board
12/2/2012 8:03:21 PM • KitchenAid... • Answered on Dec 02, 2012
My oven does not want to heat up - it always stays on LO? can u help
Do the top burners act properly, meaning giving high heat? Are you seeing black soot or just low flames? Low heat all around possible the gas cutoff in the kitchen has been turned down accidently. not an expert but have experienced the same problem with my new gas stove. The valve was almost off.
11/29/2012 2:08:47 AM • KitchenAid... • Answered on Nov 29, 2012
KitchenAid KGRT607 Gas Kitchen Range Logo
107 questions posted
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
beep quit beep used work when oven came
  • Kitchen Ranges
