20 Most Recent
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Questions & Answers
Rust spots appear on the doors and arount the ice
Hi; Yes I would say its covered under a warranty. Trying to get the manufacture to repair it for free maybe not. Thats a questionable area. I would argue that the painting process had a problem that day. But if no warranty open door and dry off really good then brush with a steel brush to bring up rust then spray or paint on a rust eliminator. After it dries You can call Your local paint store for some appliance epoxy paint. Do a smooth job from the begining and a good flat surface will be ready for Your door gaskets...alpharome416
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
My refrigerator is not getting cold what is the
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
I have a ten year
before i replaced the defrost timer again i would replace the defrost termonator . pt # 2000528 / this could cause the problem and the other is the main board pt 4288656 . both of these could cause this the bi metal thermo may not be reseting as most don't when going bad and the control board is more common and it's prob the problem .. mm / if you were to do a maintaince program you would replace the heater and the bi metal every 4 to 5 yrs as they do ware out .. and ck all fans for speed and air flow and clean coils at lease 1 a year . hope this helps mm ..
Oven is emitting gas odor
how long does it take before the flame lites?usually it's longer than a minute and the ignitor needs to be changed,it should lite in like 30 to 40 seconds no longer,next time send model number,this showed up in the refrigerator section
I hear a hissing sound
iF I REMEMBER RIGHT YOU HAVE TO PUSH IT IN TO TURN IT..YOU MAY NEED TO REMOVE THE KICK PLATE TO SEE WHAT YOUR DOING BETTER. ONCE I FOUND A WATER LINE WITH A SMALL CRACK IN IT UNDER THE REF. TAKE A LIGHT AND LOCATE THE LEAK.i DONT SEE HOW A DIRTY OR OLD FILTER WOULD CAUSE A LEAK. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/dude_653d05454b389bba
My superba refrigerator recently keeps tripping
well usually several plugs are on the same breaker and just because u use a different plug dont mean u r using another breaker try replacing the breaker and see if this cures the problem breakers sometimes get weak and trip when they need replacing but make sure u put in the same size if it still does it then u have something overamping because of being dirty or clogged up around the fridge or behind it or under it make sure its clean all around and try unplugging a couple of things on the outlets and see if it stops tripping
Top compressor area is making a 'sing song'
If it's a whistle, or chirp like sound, then find what is rubbing together to cause the noise. If it is a low pumping sound that seems to be coming from internal to the compressor, then that is the way they sound.
I might caution you, if the tech's that are putting R-12 in the system are doing so through clamp on type service ports, they are violating the EPA mandate for the type of equipment used to service A/C and refrigeration equipment. Besides the fact that it will continue to leak because the type of fittings used will not hold R-12.
