20 Most Recent KitchenAid KSSP48QMS Side by Side Refrigerator Questions & Answers
0answers
0answers
0answers
0answers
My icebox freeze on both sides on a side by
Set the dials to the middle settings, if this does not rectify the issue,
see if the thermostat will shut off the unit at its lowest temp setting with the cold box temps as reported, if the compressors still running , the thermostats bad.
12/24/2010 1:29:51 AM • KitchenAid... • Answered on Dec 24, 2010
What is holiday mode? is
In Holiday Mode, the freezer will not automatically defrost as often in order to conserve energy. I believe some models doesn't turn on the lights when this mode is activated.
11/23/2010 6:44:34 PM • KitchenAid... • Answered on Nov 23, 2010
How do i replace a filter in GE side by side
It's a twist off cartrage in the upper right hand side of the refrigerator section. Refer to your owners manual for instructions.
8/21/2009 2:32:50 AM • KitchenAid... • Answered on Aug 21, 2009
Water filter removal
Lawrence, you will need to get a filter plug that replaces the filter, if you don't want to use the fridge filter element, otherwise, you will not be able to get ice and water from the dispenser.
I tried to look up the part you need, but the model number you provided appears to be missing some alpha or digits. I would suggest you contact KitchenAid or the retailer where you purchased it from, and ask them to order you the plug. Sometimes these fridges are shipped with the bypass plug installed and the new filter gets put in at installation by the delivery people, etc. If yours already had the filter installed, you'll have to buy a filter cap/plug in order to still get ice and water from the fridge.
Here's a link to a possible plug for your fridge:
http://store.appliancezone.com/servlet/-strse-56329/appliances-parts-repairs-replacements/Detail
Here's another one you can look at, just scroll down and you'll see the plugs mid-way down the page.
http://www.easyapplianceparts.com/appliancepartlist.aspx?Brand=KitchenAid&Appliance=Refrigerator&ModelNum=&Type=Filter%2C+Lint+-+Air+-+Water+-+Grease&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
I hope you find this Very Helpful and best regards!
8/20/2009 6:19:54 PM • KitchenAid... • Answered on Aug 20, 2009
2answers
Water filter question
WOW! I'd say that the filter is definately due for replacement.
The manufacturer recommends the filter be changed every 6-8 months, as with ice and water dispensers in the door, folks tend to use the chilled water and ice more often, hence you get alot of gallons of water thru the fridge each month.
Once you replace the filter, you'll need to flush out the lines, (see the instructions with the new filter) to get rid of any loose carbon in the filter element, but once you done this, you should also notice better water flow and better tasting water and ice cubes too.
I tend to change my ice/water filter on my fridge every year when I change my smoke detector batteries. That way, I don't forget, sort of like my personal "once-a-year" house task list to change batteries, filters, resetting timers, etc., etc.
It's a good idea to change these smaller filters at a minimum of once a year, as they are no longer providing the filtration you want, and can actually be letting some of the contaminents fow out and into your water and cubes.
Hope you find this Very Helpful and best regards!
8/20/2009 4:28:13 PM • KitchenAid... • Answered on Aug 20, 2009
REFRIGERATOR SIDE-BY-SIDE IS FREEZING UP ALL THE TIME
Could be low on refrigerant
3/8/2008 7:00:54 PM • KitchenAid... • Answered on Mar 08, 2008
2answers
KitchenAid French door refrigerator. How do I repair a non-working water Dispenser on it please?
Troubleshoot step by step and if that fails, resort to a professional: Check the Basics: Make sure the refrigerator is plugged in and receiving power. Verify that the water supply to the refrigerator is turned on. Inspect the Dispenser Actuator: The dispenser actuator is the component that activates the switch to send voltage to the dispenser. Check if the dispenser actuator is damaged. If so, replace it with a new one. I list a procedure for testing this actuator at the end of these basic steps. Frozen Water Tube: Disconnect the water supply tube at the bottom of the door. Blow air through it. If air doesn't pass through, the water supply tube may be frozen. Thaw it out and ensure the freezer is set to the proper temperature (0-10°F) to prevent future freezing. Water Inlet Valve: The water inlet valve opens to supply water to the dispenser. Ensure the water pressure to the valve is at least 20 psi. Use a multimeter to test the water inlet valve for continuity. If it lacks continuity, replace it. Check Water Filter: Remove the water filter and dispense water. If flow increases, the filter may be clogged or incorrectly installed. Replace the water filter if needed. Verify Water Supply Valve: Ensure the water supply valve (connected to the refrigerator) is fully open. If disconnected during service, it might not have been turned back on fully. And now, the testing of the actuator. To determine whether the dispenser actuator in your KitchenAid refrigerator is damaged, follow these steps: Visual Inspection: Look closely at the dispenser actuator. Check for any visible signs of damage, such as cracks, chips, or breakage. If you notice any physical damage, it's likely that the actuator needs replacement. Functional Test: Press the dispenser lever or button as you normally would to dispense water. Observe the response: Does the actuator move smoothly and engage the switch behind it? If the actuator feels stiff, loose, or doesn't move at all, it may be damaged. Listen for Clicking: When you press the dispenser lever, listen for a clicking sound. The actuator should make a distinct click as it activates the switch. If there's no click or an unusual noise, it could indicate a damaged actuator. Multimeter Test (Advanced): If you have a multimeter, you can perform a continuity test on the actuator. Disconnect the refrigerator from power. Remove the actuator cover (if applicable) to access the actuator. Set the multimeter to the continuity (ohms) setting. Touch the multimeter probes to the actuator terminals. If there's no continuity (infinite resistance), the actuator is likely faulty. Remember to exercise caution when working with electrical components. If you're unsure or uncomfortable performing these checks, consider seeking professional repair assistance. Remember to consult your Owner's Manual for specific instructions related to your model. Much of this information comes from the RepairClinic site.
3/17/2024 4:42:35 AM • KitchenAid... • Answered on Mar 17, 2024
KitchenAid Refrigerator Model KSRS25Q. Are Replacement door seals available?
Question edited for a lot more clarity, 'make model (what it is)'. Question moved for correct category. Yes they are, direct or from Parts Suppliers. https://www.google.com/search?q=KSRS25Q+WH11+door+gasket ..
1/4/2024 10:29:11 PM • KitchenAid... • Answered on Jan 04, 2024
KitchenAid refrigerator superba is not cooling. Frizzer is fine
Possibly you r hhermostat in Fridge section gone bad. (if freezer working then most likely (if freezer at top & fridge has Iced up or food in the freezer or fridge Is Blocking the Air vents inside that circulates the cool air flow to Bottom or top, check & listen to see if Fan is working inside freezer /fridge worst case scenario is (if you have a p.c board on top , that could b a Fault there also (then you need a Tech, ).
10/26/2023 4:15:12 AM • KitchenAid... • Answered on Oct 26, 2023
KitchenAid KSSP48QMS Side by Side Refrigerator Logo
Popular Tags
22 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
holiday mode
  • Refrigerators
