20 Most Recent
Kenneth Cole KC3289 Wrist Watch Questions & Answers
Need a link for band
- The original bands for that watch are very difficult to come by. But having a spare part or two never hurt either.
- Hope this helps.
How do you get a
mcdevito75 Here, You"ll need a tool called a spring bar remover tool available on ebay, but by the time you get the tool you can have a small watch repair shop in your area replace the band and for about the same money as the tool.
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Taking the battery out
some watches have a special way to open..nut by push/pull out the back but by rotating it .in this case it hase some small cuts in the back cover .if this so,it just might need to rotate.
How to set time of the Kenneth Cole reaction watch RK5072
They all set pretty much the same. Here is the general walk through from the Cole site:
Press the lower left button on the Kenneth Cole digital watches to cycle through the various modes. Press it three times to get into time mode (the face should be blinking). Press the upper right-hand button to change the seconds. Press the lower right-hand button to select the minutes.
WHAT IS THE BATTERY SIZE FOR A KENNETH COLE KC50477003WATCH?
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
How use kenneth cole kc 9110
Instruction Video on How to Size Your Ceramics Watch Kenneth Cole Touch Activated Kenneth Cole New York (US) Kenneth Cole New York (Int'l English) Kenneth Cole New York French (FR) Kenneth Cole New York German (DE) Kenneth Cole New York Italian (IT) Kenneth Cole New York Japanese (JP) Kenneth Cole New York Spanish (ES) Kenneth Cole New York (Simplified Chinese) Kenneth Cole New York (4-Eye Chronograph Movement) Kenneth Cole Analog-Digital Touch Screen Instruction Manual - Korean (KR) Kenneth Cole Reaction unlisted: Analog-Digital: UL1052, UL1069, UL1102, UL1103, UL1171 (EN) unlisted: Analog-Digital: UL1002, UL1070, UL1095, UL1097, UL1099 (EN)unlisted: Digital Instructions (EN) unlisted: UL1154, UL1155, UL1156 (EN)unlisted: Instruction Manual.
Ul 1008 analog portion does not work
Are the hands moving but out of step with the digital display?
If so then try pressing the "mode" button to reach a mode that allows you to set the hands (on my Casio it is "HS"), I would expect something similar on yours.
You can then alter the hands by pressing one of the other buttons. I would expect one button to advance the hands and another to ****** them.
Happy experimenting!
