click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps you if you dont have a motherboard disc you will have to download the drivers http://download.cnet.com/g02-cd35-a1-rar/3000-2098_4-200883.html http://download.cnet.com/g02-cd33-a3-rar/3000-2098_4-200366.html using this link you will be able select your drivers if these arent right you will find free sound drivers http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for ie:intel laptop (be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps http://majorgeeks.com/downloads35.html also this link will provide you with many freeware and share drivers hope this helps you
11 questions posted
38 Questions
25 Questions
25 Questions
25 Questions
21 Questions
