20 Most Recent Kenmore 50522 / 50524 Side by Side Refrigerator Questions & Answers
2answers
Freezer quit however fridge appears to be cooling...
if there is a fan in the freezer; in that is not working then yes OR the thermostat has gone. But the unit only has one compressor and if the fridge is working it is normally a good sign.
If you where really concerned you could call a domestic refrig tech they could fix it.
Hope that this helps
6/21/2020 8:45:23 AM • Kenmore 50522 /... • Answered on Jun 21, 2020
Ice maker will not make ice model 795.71053.010
There is a lever in the ice box push it down, it is the cutoff switch Tony Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
1/15/2018 1:29:59 AM • Kenmore 50522 /... • Answered on Jan 15, 2018
2answers
Comp kicks on and then off
installed 3n1 and still did not start compressor.
11/26/2015 8:28:01 AM • Kenmore 50522 /... • Answered on Nov 26, 2015
We have a kenmore top and bottom with a warm fridge and a really cold freezer?
Check that the fan is operating. If the bottom of the fridge cold & the top warm then thats probably the issue.
5/31/2014 4:27:11 AM • Kenmore 50522 /... • Answered on May 31, 2014
I have a Kenmore Model #363.9552410 that is not cooling properly. The coils undrneath were clogged so I cleaned them thoroughly. It is running better but having trouble cooling to 40 degrees or lowe
Check to see if the fan blade by the compressor has a lint build up on the blade. This could also cause poor performance. Make sure the controls are set to median settings if both controls are set to max this can shut off the air to the fresh food section. If there is a damper to the fresh food section it could be not opening.
5/17/2014 5:43:45 PM • Kenmore 50522 /... • Answered on May 17, 2014
Ice maker in refridgerator freezer won't make ice
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
2/14/2014 4:34:39 PM • Kenmore 50522 /... • Answered on Feb 14, 2014
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
2/7/2014 2:46:13 AM • Kenmore 50522 /... • Answered on Feb 07, 2014
0answers
Can refrigerator work if freezer is not in a kemore side by side?
Unfortunately, no. If your freezer is not cooling then your refrigerator side will also get warm. The freezer is the source of cooling and it uses a fan to force the cold air into the refrigerator side. I would suggest calling a repairman to look at it for you to find out if it is fixable. It could just be something simple and does not always mean that you have to replace the unit, but that may be a possibility as well. Sorry!
12/5/2013 6:00:56 PM • Kenmore 50522 /... • Answered on Dec 05, 2013
Ice maker making water
The origional problem was probably not the icemaker but the electronic controller that sends power to the icemaker.
11/22/2013 9:12:28 AM • Kenmore 50522 /... • Answered on Nov 22, 2013
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
313 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
kenmore refrigerator
  • Refrigerators
