20 Most Recent Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Questions & Answers
Age of kenmore refrigerator, model 55061
Kenmore side-by-side Fridge Model 106-59522801 with ice and water filter, serial No. HRY 4657443
10/6/2018 8:04:43 PM • Kenmore 22.0 cu.... • Answered on Oct 06, 2018
22 cf kenmore side by side not very cold. Large
also perhaps the defrost timer is bad, not allowing the defrost heater to come on and melt the ice as it should? Or the defrost heater itself could be bad -
10/7/2017 7:54:22 AM • Kenmore 22.0 cu.... • Answered on Oct 07, 2017
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
9/2/2017 2:34:07 PM • Kenmore 22.0 cu.... • Answered on Sep 02, 2017
Why is My filter hose leaking at the neck right before connection to tightening hose to filter under the sink.
Sounds like either the hose has a hole in it, it isn't seated right, or it isn't tightened sufficiently at the connection. Most often, leaks by the connection are actually leaks at the connection and the water is running down the pipe a bit. Try turning the water off in the main system or at any valve before the connection and then tightening the connection another quarter turn. While directions caution us to be careful not to tighten too tightly, we must insure that our connections are sufficiently tight so that the water doesn't leak out. You may also take the connection off and make sure you have a layer of plumber's silicon tape on the threads and then put the connection back together, making sure it is tight enough so that there are no leaks. Less likely, but possibly, the hose may have a small hole in it. In this case, the water is likely spurting out of the hole rather than slowly leaking down the pipe.
9/18/2014 7:00:32 PM • Kenmore 22.0 cu.... • Answered on Sep 18, 2014
2answers
Changing the water filter in my Frigidaire
My Frigidaire PureSource water filter housing wouldn't unscrew either. Even with the supplied plastic "wrench" and later a cloth-covered pipe wrench, it wouldn't budge. Since both my icemaker and my door dispenser stopped dispensing water, and the filter housing in the fridge wouldn't budge, I suspected that the filter was full of frozen water. (Sometimes things on the top shelf of the fridge freeze, so it was obviously too cold.) I used a hair dryer on the water filter housing for a few minutes, and then the water filter unscrewed easily. Sure enough, the whole inside was a block of frozen water. This would have been such a simple repair, HOWEVER unfortunately it turned out that I wrenched it too hard and broke the inlet valve on the housing. As soon as I thawed out the filter and reassembled, water was pouring out of the top. Took off the big cover at the top ceiling of the fridge and saw my problem. It's only about a $25 part, but I'd advise that you be careful to only turn, without rocking back and forth, the housing when trying to unscrew. I guess I wiggled it back and forth too much and cracked it.
5/28/2012 7:19:22 PM • Kenmore 22.0 cu.... • Answered on May 28, 2012
Kenmore 22 makes a noise about every half hour
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/20/2011 8:51:04 PM • Kenmore 22.0 cu.... • Answered on Sep 20, 2011
Water is collecting in bottom of freezer section.
There is usually a drain pan on the right hand side behind the front grille. It is long and skinny and pulls straight out the front. This collects the water when the freezer defrosts, then allows it to evaporate with the help of the fan for the compressor.
2/24/2011 10:37:25 PM • Kenmore 22.0 cu.... • Answered on Feb 24, 2011
We had to pull our kenmore 22 s-b-s away from the
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
10/19/2010 12:32:01 AM • Kenmore 22.0 cu.... • Answered on Oct 19, 2010
How do i figure out if my refrigerator is working
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/12/2010 2:06:50 AM • Kenmore 22.0 cu.... • Answered on Aug 12, 2010
How do you remove the tube to replace the hinge at
There is a connector that you need to disconnect. There is a small white ring that you push with your fingertips and at the same time pull the plastic line out. To reinstall just push the plastic tubing back into the connector. It is located behind the grille of your unit.
A picture of the part is linked just below.
Connector.
5/25/2010 12:45:11 PM • Kenmore 22.0 cu.... • Answered on May 25, 2010
2answers
Kenmore SbS refrigerator, water dispenser not working
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
4/30/2010 1:03:36 AM • Kenmore 22.0 cu.... • Answered on Apr 30, 2010
Refrigerators Logo
56 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
changing water filter in frigidaire
  • Refrigerators
