20 Most Recent GMC Denali 700C Road Bike Questions & Answers
Repainting via rattle-can is a bad idea - looks poor and will not hold up. As for forks, just google "overhaul threadless headset."
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
GMC Denali 700C... | Answered on Jul 30, 2017
If the wheel has nuts (not bolts) on each side you just need to loosen each one enough to remove the wheel.
GMC Denali 700C... | Answered on Jul 29, 2017
Serial numbers are generally found under the crank, stamped into the case.
GMC Denali 700C... | Answered on Dec 06, 2014
Remove the bolt and put a lock washer between the bolt and head. That or put some blue loctite on the threads. Just remember to have the head removed from the fork tube before the bolt comes out or the expander will come off in the forks.
GMC Denali 700C... | Answered on Jul 12, 2014
just go to a higher end brake pad that should work.First make sure the cable is adjusted properly, that could be the whole problem. Maybe you're just used to the bike now and are going a lot faster than you used to.
GMC Denali 700C... | Answered on Jun 23, 2013
Thats were they go ,is and unscrew / screw back up .take water bottle cage out ,put the bracket for the pump,in top put your water cage ,put bolts back in , secure it and u should be good.the only reason you shouldn't be able to fit it ,is because is not for a bicycle .
GMC Denali 700C... | Answered on May 05, 2013
Yes but you didn't tighten the actual brake assembly. Grab a 10mm to 12mm box wrench and tighten that down. You should be good to go but before you ride off into the sunset make sure to do the other set as well and to readjust the brake pads on the rims and tighten all the pads snuggly.
GMC Denali 700C... | Answered on Jan 16, 2013
GMC Denali 700C Road Bike Logo
Popular Tags
62 questions posted
Top GMC Cycling Experts
Mike
Arnie Burke
Arnie Burke
Dennis
Dennis
Are you a GMC Cycling Expert? Answer questions, earn points and help others
View Most Popular
GMC Cycling
  • GMC Cycling
Most Popular Question
brakes seem move one side tried
  • Cycling
