20 Most Recent
Marin Belvedere Commuter Road Bike Questions & Answers
Adjust handle bar height ?
looking at some pictures of this model, most appear to be using an "Aheadset" style handlebar stem, there is not any way to raise this type of stem. Your alternative is to go online or to a local bike shop and purchase a new stem that will fit your fork and handlebar that has a higher pitch angle to it, or a compatible adjustable stem that pivots. Expect to pay $25-$50 or more for a new handlebar stem, not including labor to install.
Need to put new sprockets on and not sure I
I assume you mean the gear sprockets on the rear hub. If its a Shimano type, the most important thing is to place each sprocket on with the tooth markings OUTWARDS. Other than that, big one first, small one last. Tighten the locknut.
Could a hardtail be used
There is no reason to doubt the physycal load-bearing capacity of a bike that isn't built stupid-light to begin with. Your wheels should be strong enough for the added weight. Get some good road-worthy tires but keep the size large enough for rim protection.
You won't like how it feels if you stand and pedal but it can be done. I've toured on full suspension. I find a mountain bike set up for the road frees my eyes for scenery instead of scanning the pavement for pebbles and cracks.
Get a Blackburn or comparable rear rack and slap some panniers and a rack-pack on it. I'd also consider adding bar-ends for variety in your hand positions as the miles pile up. I even add an aero bar for the long descents of mountainous areas.
If you can find a front pannier or rack system that will work with your fork you might opt for that instead or in addition to the rear rack. Your weight distribution should not all be on the rear. I find front panniers slow the steering down in a pleasant way, making rider input smoother and resisting sudden swerves that can make you loose front traction.
Added weight is not the drag on the actual riding experience that it is on paper. Once you're in motion you tend to keep it, so it pays to rider smarter and plan for red lights by timing your arrival for the green so you don't have to invest all that energy into accelerating again. Tandem riders catch onto this in time for the same reasons. Loaded downhills are a thrill.
Test ride the loaded rig before your trip. Do some long hills just so you know how to adjust your effort. Have fun.
Tomahawk E Series Exercise bike loud peddling sound
Standard WD40 is just a 'quick fix' as it isn't an actual oil unless the can is clearly labelled as "Bike All Condition Lubricant". It'll be best to buy a proper light oil like 3in1, 151 Super oil or an actual chain lube.
This 'clickey' noise. Is it random and happening every so often or is it a constant, regular click that changes with the speed your pedalling at? Check for slack in the chain. as you wiggle the chain up and down there should only be about a centimetre of movement in the chain. If it's too slack or too tight it can make strange noises. Check the axle bolts and nuts to make sure they're not loose. Check the wheel is mounted straight. If it's turned left or right the chain will 'skip' as it's slightly missing the cog teeth on the wheel. Use the frame at the rear end of the wheel as reference and measure how far the side of the wheel is from the frame on both sides. It should be about the same both sides.
9/22/2023 12:16:04 PM •
Cycling
Answered
on Sep 22, 2023
New Balance 6100 Recumbent Bike making a clanking noise when pedaling
I have done a tremendous amount of research on this problem. New Balance (Fitness Quest) is out of business as of late 2012 and no parts are available. The main bearing or crank bearing set is 100% compatible with Proform part number 295560. Since New Balance put their name on this product, they have stated they will reimburse customers for the repairs.
4/5/2023 11:21:09 AM •
Cycling
Answered
on Apr 05, 2023
