20 Most Recent
Huffy So Sweet Girls 20-Inch Bike Questions & Answers
Missing front rim where can I order new one?
go to your local bike shop, they can get you a 20" wheel that is much better quality than what was originally spec'd on the bike for about $30. Huffy doesn't sell OEM replacement parts for their bikes.
Brake assembly help!!!!!!!!!
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
Parts for Huffy Maxx? I need a left side crank and nut.
Question moved from Computers to maker category.
Order Replacement Parts
Huffy Bikes
https://www.huffybikes.com > parts
We make it easy. Here you can order free warranty parts, or purchase the replacement parts you need. *Note: Battery products including ride-on toys, ...
Missing: Maxx ā' Show results with:
Maxx
Order Replacement Parts-Bikes, Scooter, Ride On Toys
Huffy Bikes
https://www.huffybikes.com > index > findproduct
Order replacement parts for your bikes, scooters, and battery ride on toys. ... and FAQs about warranties, warranty parts, returns and order cancellations.
Maxx
Huffy Vintage Bike Parts for sale
eBay
https://www.ebay.com > ... > Vintage Bicycle Parts
Get the best deals on Huffy Vintage Bike Parts when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your favorite ...
Bike Parts and Accessories
Huffy Bikes
https://www.huffybikes.com > parts-accessories
Results 1 - 8 of 8 - Bicycle parts, smartphone holders, repair kits, and officially-licensed accessories from Disney and Marvel allow you to get the most out ...
Maxx
Model and year of huffy bike serial # 4H114288
Not possible to ID by serial number, and even if it was it's not important. Huffy's are not valuable and parts are not specific to a particular brand, let alone year or model of bike. The model name is printed on the bike's frame. If not there bike has been cheaply repainted, possibly because it's stolen.
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area
or you can take the hub apart and fill with a very light grease
11/11/2022 12:13:34 AM •
Huffy Cycling
Answered
on Nov 11, 2022
How to put on a rear axle assemly on a 26 inch perfect frame mens dellusso huffy bicycle
Are you asking about the internal parts like bearings, races, and such, or are you asking how to lace a rim?
The first one is fairly straight forward, so I am guessing the second.
I have done quite a bit with bikes and never attempted since it is a science and art. There are a few youtube videos but they make it look so easy. One on the issues I hit when thinking about it is having a good tuning stand and dishing guide to get the rim to run in the middle if front wheel of a bit off center on the rear due to the gear cob. I gave up trying to find the tools, right spokes, (before internet) and opted to buy a whole rim.
https://m.youtube.com/watch?v=OYl4NO5m16Q
HOW TO DETACH TRAINING WHEEL FROM hUFFY tODDLER BIKE
- Begin by removing the outer nut. Using a 15mm spanner (closed end preferred), turn the nut in an anti-clockwise direction when looking at the nut from the same side as the nut is on (Dia.1 below)
- Next remove the outer nut, round washer, training wheel and square stabiliser washer. DO NOT loosen or remove inner nut!!
Do 10 speed huffy mountain bikes have master link on chain for removal?
No, they do not - a chain tool has to be used. Also, a 10 speed (2 gears in front, 5 in the rear) would be quite old, so the rear gear cluster (freewheel) will be worn as well as the chain, and also takes a specialized tool to remove. Replacing both on a Huffy will cost more than the bike is worth.
