20 Most Recent Mountain Best Bikes NFL Michigan U 26-Inch Adult Bike Questions & Answers
My MTB handles seem to be to loose , when I let go
This sounds like te neck of the bike has come loose, tighten the bolt that's right above the frame and underneath the handle bars, there will also be a little washer-type thing that's directly under the bolt and you must tighten that in order to shield the bearing from moisture. hope this helps, Daniel
10/29/2010 8:19:41 AM • Mountain Best... • Answered on Oct 29, 2010
My mountain bike handle bars are loose
Compare to the ones in this link...
http://www.sheldonbrown.com/handsup.html
5/21/2010 10:52:11 AM • Mountain Best... • Answered on May 21, 2010
Bicycle Brakes Problem
First thing to check with a such a brake problem is your brake pads these are the two cushion like
things that cling to the wheel once you press the brakes.
If they are worn you should change them.
Sometimes after rainy days or riding throw water the brakes also make noise.
Let us know how it went.
10/29/2008 11:50:28 AM • Mountain Best... • Answered on Oct 29, 2008
2answers
How do you out on a new Full Suspension Spring on the 24" NEXT PX 4.0 Boys Mountain Bike?
Sorry, this question doesn't make sense. Are you trying to remove the spring or are you trying to adjust it?
10/23/2023 7:40:05 PM • Mountain Cycling • Answered on Oct 23, 2023
Owners manual for a Nishiki Colorado XC Mountain Bike
No specific manual, but they are all the same basics https://www.google.com/search?q=Nishiki+Colorado+XC+Mountain+Bike+manual They are made by Kawamura Nishiki is a brand of bicycles designed, specified, marketed and distributed by West Coast Cycle in the United States, initially manufactured by Kawamura Cycle Co. in Kobe, Japan, and subsequently by Giant of Taiwan. The bicycles were first marketed under the American Eagle brand beginning in 1965[1] and later under the Nishiki brand until 2001. https://www.google.com/search?q=Kawamura+mountain+bike+manual ..
1/18/2023 5:26:22 PM • Mountain Cycling • Answered on Jan 18, 2023
2answers
What size is my bottom bracket for a Nishiki Kinzua 29 Men's Mountain Bike
hi if i remember correctly to size up for a bottom bracket, flip your bike upside down resting on handle bars and seat carefully not to damage anything, and where the bottom bracket go's through the frame of the bike you take a tape measure and measure the width of only the frame housing where the bottom bracket go's into this is a lot easier to do when the crank arms are removed. also on some bottom brackets when removed from the bike has all the data stamped on it depending on the type of bottom bracket. if not measure the width of the frame where the bottom bracket sits in too and that will be the size of the bottom bracket you need, then determine which type it is once you have remove the cranks arm which are attached to the bottom bracket could be splined drive or square tapered type bottom bracket basically the shape of the metal part that the crank arms push and bolt on to then match up on a cycle part website.
7/18/2022 3:56:01 AM • Mountain Cycling • Answered on Jul 18, 2022
I need disconnect front wheel mountain bike forfringe super cycle 550 zoom full suspension
The front wheel is normally held in with one of two common methods. A basic nut on each end of the axle or a 'skewer' pin. On most bike that do not have disc brakes you might need to unhook the brake arms to allow the tyre to clear the brake pads. For the nut type simply slacken the nuts and drop the wheel out of the C shaped notches the axle sits in. The skewer type is a small lever on one side you swing all the way over then slacken the nut on the opposite side two or three turns. The wheel should then drop down and out.
5/22/2022 10:59:36 PM • Mountain Cycling • Answered on May 22, 2022
2answers
Mountain bike helmets
you have a repair problem with yours?
5/2/2021 11:29:03 PM • Mountain Cycling • Answered on May 02, 2021
4answers
I have no clue how to tighten the chain on a Moongoose XR 15 mountain bike
loosen rear tire pull back and tighten when chain slack is removed
7/30/2020 6:39:40 AM • Mountain Cycling • Answered on Jul 30, 2020
2answers
Can the rear wheel bearings on a murray sabre herculite 18 speed mountain bicycle be adjusted?
Yes it can, This web has diagrams and instructions with pictures,http://www.bikewebsite.com/rhub.htm.
10/10/2019 3:47:46 PM • Mountain Cycling • Answered on Oct 10, 2019
I bought Roadmaster 26" Granite Peak Womens Mountain Bike, but when I tried to ride it my shoe would hit the wheel every single time. Why it happend?
Unless your feet are extremely angled in or out on the pedals it is not possilbe for your shoes to hit either wheel while traveling straight ahead. When you turn you should coast.
7/15/2019 2:57:55 AM • Mountain Cycling • Answered on Jul 15, 2019
3answers
My chain has a dent that causes the chain to skip gears while riding. I believe that I need a new chain but I am unsure of size of chain needed for a 15 speed parowan next women's mountain bike. Can you help me ?
No, you don't need to contact the manufacturer. There are two possible solutions. First, if the chain is sized one full link (inner+outer) too long it can just be shortened. The other option is a new chain (made for 5 gears in back) but a new chain will not always mesh with the gears if the bike has a lot of miles on it, especially if the small gears in the back have been ridden a lot. Either way I would really suggest you get some local help, as sizing and installing a chain requires both knowledge and a specialized tool.
6/30/2019 10:41:42 AM • Mountain Cycling • Answered on Jun 30, 2019
Need an owners manual for a 26” Women’s Nishiki Pueblo Mountain Bike
That bike was made from 1993-1998. It's a standard Cro-Moly (i.e. Steel) non-suspension mtn bike. In other words, there is nothing unique about it that would require an owner's manual. I might suggest you post the actual issue with the bike to get some feedback as to how to deal with it.
5/17/2019 2:49:44 PM • Mountain Cycling • Answered on May 17, 2019
The handle bars are loose on my daughter's 2016 Nishiki Pueblo mountain bike. How do I tighten?
tighten the center bolt of the head stock that holds the handle bars
9/18/2018 1:11:06 AM • Mountain Cycling • Answered on Sep 18, 2018
Want a manual that shows me the gears system on a Sumer 18 mountain bike’
Forget the "parens" and tell us what you mean by "show the gear system". Do you want to know how to shift the gears or how to fix them. Either way the manual will be of no help.
6/30/2018 6:13:04 PM • Mountain Cycling • Answered on Jun 30, 2018
Mountain Best Bikes NFL Michigan U 26-Inch  Adult Bike  Logo
3 questions posted
Top Mountain Cycling Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
View Most Popular
Mountain Cycling
  • Mountain Cycling
Most Popular Question
mtb handles seem loose when let go
  • Cycling
