20 Most Recent
Stamina Products Stamina Pro 5300 Silent Magnetic Resistance Upright Bike Questions & Answers
Stamina R360s UP/DOWN magnetic restistance buttons not working
mine did the same thing.. unhook the plugs that are under the seat running from the handles and touch a screwdriver to two of the prongs on either side of the plug and it will engage the button for you on which ever side you do it.. the up or down side
I just tried my Stamina e-1000 eliptical for the
Check the upper console to see if you have a loose connections and one of them is the speed sensor connection , if all connections are good then it looks like the sensor itself inside the main casing by the flywheel
I have the same problem
Whichever way u turned the adjustments, just do the opposite and maybe u will get a comfortable setting for ur workout......sodeep
I need the wheel bearing assembly for a Stamina
If your mechanically incline, Pull out old wheel bearing, if still in half way good condition, take to bike/auto shop see if they can find suitable replacement or rebuild the bearing it self. make sure when putting back in to use very good grease. I have same problem, since I can't find parts, those would be the best possible solutions.
