20 Most Recent Kenmore 30 in. 32384 / 32385 / 32389 Gas Cooktop Questions & Answers
Control panel
Probably couple of hundred dollars installed. Might be time to replace stove!!
1/29/2015 6:12:24 PM • Kenmore 30 in.... • Answered on Jan 29, 2015
When I cleaned my Dad's gas range the labels came off of the control buttons. I need to know what they were .
You might take some close up photos of the range and send them to gas range parts suppliers to see if they can recognize it and give you the info you want. Maybe try: http://www.partselect.com/Entry.aspx?Source=GAWS&Term=Range+Parts&gclid=CP-hgZz41L8CFZRj7Aodqx0AIw Good luck Pete
7/20/2014 10:30:14 PM • Kenmore 30 in.... • Answered on Jul 20, 2014
Replacing burner pans for a sears gas cook top
meldah
8/28/2013 3:01:40 PM • Kenmore 30 in.... • Answered on Aug 28, 2013
The igniter on the cook
Hi,Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...Gas Range Repair Burners Keep on Clicking heatman101
9/22/2011 3:38:01 AM • Kenmore 30 in.... • Answered on Sep 22, 2011
Gas stove digital clock
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/5/2010 2:56:48 AM • Kenmore 30 in.... • Answered on Sep 05, 2010
How do you stop the
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/18/2010 9:48:30 PM • Kenmore 30 in.... • Answered on Aug 18, 2010
I have a kenmore gas range and on the display is
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
4/18/2010 3:10:38 AM • Kenmore 30 in.... • Answered on Apr 18, 2010
Reassembling a Kenmore 30 in. induction cooktop
The best way to understand how its installed would be to check out its user manual. Since you have not provided the exact model number I was unable too narraw it down to help you with correct manual. But please click on the link bellow to download the appropriate manual:
http://www.hammerwall.com/Manuals/Kenmore/9-36/Lookup/Home%20Appliances/65/
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
4/6/2010 9:43:25 AM • Kenmore 30 in.... • Answered on Apr 06, 2010
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
3/13/2010 3:48:59 PM • Kenmore 30 in.... • Answered on Mar 13, 2010
Safely remove knobs from 50's Kenmore gas stove
The safest thing to do would be to turn off the power ( un-plug it or turn off the breaker) or the gas or both to the unit. Turning off the power would probably be easier. There should be a gas shut off valve behind it.
1/7/2010 6:37:47 PM • Kenmore 30 in.... • Answered on Jan 07, 2010
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
5/17/2009 4:12:15 AM • Kenmore 30 in.... • Answered on May 17, 2009
Is there a flame adjustment on Kenmore 32385
try to clean the injector at the bottom of burner base by using a small niddle then after this use a vaccium in the same place.tnx
12/2/2008 2:13:52 PM • Kenmore 30 in.... • Answered on Dec 02, 2008
2answers
Kenmore elite 36'' glass top cook top beeps and displays eo 11
so does mine
1/15/2019 10:42:07 AM • Kenmore Cooktops • Answered on Jan 15, 2019
Where can I order Decals for kenmore cooktop
Check out stovedecals.com - they offer Kenmore stove decals for your stove or cooktop.
12/29/2018 8:18:17 AM • Kenmore Cooktops • Answered on Dec 29, 2018
How do I unlock the cooktops on Kenmore Elite Electric Range model #C970-440935
Clear the lock mechanism -- as indicated by the DOOR LOC light -- by pressing and holding in the oven door light switch for 20 to 30 seconds. While the switch is depressed, the latch motor will gradually withdraw the lock, allowing you to open your oven door.
10/9/2018 10:09:24 PM • Kenmore Cooktops • Answered on Oct 09, 2018
I just installed a kenmore gas cooktop #32539. My connections are all good, but I smell gas! Seems to be leaking from inside the cooktop. New
Shut your gas off at the tank or meter valve. Open windows and doors and vacate. Call an appliance or gas technician!
7/12/2018 4:51:12 PM • Kenmore Cooktops • Answered on Jul 12, 2018
I have a Kenmore Elite Electric Range with Induction Cooktop #C970-440032 with an error code E074
Suggest down load the owners manual online and reference error codes.
3/21/2018 11:00:26 PM • Kenmore Cooktops • Answered on Mar 21, 2018
Kenmore 30 in. 32384 / 32385 / 32389 Gas Cooktop Logo
20 questions posted
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Cooktops
  • Kenmore Cooktops
Most Popular Question
kenmore gas range display
  • Cooktops
